e1
Hi all, with e1 , is this classed as a leased line ? or can you run an e1 circuit across to any destination ? does the circuit have to be end to end ?
many thanks
1 REPLY
Re: e1
HI Carl,
Normally E1 circuit will be a Leased Line model and in other words Leased Line will be used as end to end connectivity.
Pls Rate if Helps
Best Regards,
Guru Prasad R
97
