06-04-2014 11:51 AM - edited 03-07-2019 07:38 PM
I have a couple of internal eBGP links between ASR1001 and C4500X, configured via a port-channel. Following a failure of either the link or one of the network devices I want the eBGP session to drop rather than wait for the timers to expire.
I have appled bgp fast-external-failover under the router process, this didn't make any difference. The devices accept the command, it doesnt show up in the output of sh run, so either its on by default or doesnt work as described.
After reading up I then found the fall-over command that I can append to a neighbour statement, so tried that, again following a directly connected link failure the eBGP session remans up, eventually timing out.
I then considered BFD which would be my choice in this type of setup, but it appears not to be supported on the port channel. I'm still investigating this.
Anyone got any other suggestions on how I can achieve a faster failover?
Andy
06-04-2014 03:51 PM
Hello
I have found on certain ios that you can configure BFD in bgp stanza but it doesn't allow interface configuration of the interval timers, and the same applies to eigrp/ospf regards show bfd commands.
That said bgp, even though its supports fast-fail over and BFD I was on the understanding this protocol was design no t for fast convergence but stability given it WAN capabilities.
However if BFD inst applicable you could always drop the timers.
rouer bgp xx
timers bgp 3 10
res
Paul.
06-09-2014 03:51 AM
Thanks Paul, I applied those timers, which reduced the convergence time.
Andy
