Webcast-Catalyst9k
edge distribution / enterprise edge models
Hi all
Can you tell me what the majority use for your edge distribution model and enterprise WAN model
We have a a campus core which should connect to the edge,
would you typically go from core, to a firewall, then to a mulitlayer switch or ASR router, then this would connect your internet / WAN models etc ?
1 ACCEPTED SOLUTION
Hi Carl,
That is what good and as per best practice.
So that your ASR routers facing your provider switches at perimeter.
And your ASA outside interface will connect to your ASR and inside interface to your core switch
Please rate the helpfull posts.
Naidu.
Hi Carl,
I would like and hoping as best practice like this...
1. ASR routing facing the internet/WAN
2. Your Firewall connect to your ASR router.
3. Firewall connect to your Core or multi layer switch.
Naidu.
hi there
My idea, would be
Core connects to ASA firewall
outside interface connects to vlan on 2 x ASR routers running HSRP
ASR router then connects to third party WAN switches,  Internet firewall, VPN module etc
this sound good ?
Hi Carl,
Naidu.
Re: edge distribution / enterprise edge models
replace Asa with juniper
605
