03-18-2008 12:26 PM - edited 03-05-2019 09:49 PM
I want to set up NAT on this router so outside service can print to inside printer.
Printing is not working. Also, I can not extended ping or traceroute from outside subnets to xxx.39.25.51 (printer).
What am I missing?
Thx.
>START EDITED CONFIG:
>#sho run
Building configuration...
Current configuration : 8121 bytes
version 12.4
interface FastEthernet0/0
description Internal_LAN_Interface
ip address 10.58.0.2 255.255.255.252
ip nat inside
ip virtual-reassembly
duplex full
speed 100
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/0/0
description WAN_Interface
switchport access vlan 33
interface FastEthernet0/0/1
description OUTSIDE _Interface
switchport access vlan 31
interface FastEthernet0/0/3
duplex full
speed 100
interface Vlan1
no ip address
interface Vlan31
ip address xxx.39.25.50 255.255.255.240 secondary
ip address yyy.86.222.146 255.255.255.240
ip nat outside
ip classless
ip route yyy.0.0.0 255.0.0.0 yyy.86.222.145
ip route zzz.69.0.0 255.255.0.0 xxx.39.25.49
ip nat outside source static xxx.39.25.51 10.56.1.178 extendable
>end of cfg
(note:zzz=original source subnet,yyy= serial int 1 hop outside, and xxx= ethernet int outside)
VLAN1=10.56.x.x/19 and is on 4507 with interface 10.58.0.1
#>sho ip route 10.56.1.178
Routing entry for 10.56.0.0/16
Known via "static", distance 1, metric 0
Routing Descriptor Blocks:
* 10.58.0.1
Route metric is 0, traffic share count is 1
from 10.58.0.1 (4507) 10.56.1.178 is direct connected and other pertinent subnets have next hop 10.58.0.2
Thanks for any advice.
Solved! Go to Solution.
03-18-2008 12:46 PM
03-18-2008 12:46 PM
ip nat inside source 10.56.1.178 xxx.39.25.51 extendable
Jon
03-18-2008 01:50 PM
That was it! Thanks Jon. 5pts for the quick response.
