Webcast-Catalyst9k
EIGRP Advertising Routes
Is this possible.
What I'm wanting to achieve is to route traffic to two hosts via a one link but the rest of the subnet via a different link.
My plan is to advertise the specific host addresses through eigrp on router 1. Static routes on the other side would return the traffic from these two hosts.
On my other router I would have a static route to the subnet which points to a different hop and would be redistributed into EIGRP.
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: EIGRP Advertising Routes
Darren
Yes that would work as the most specific route is always used.
You could also use PBR if you wanted to.
Jon
1 REPLY
Darren
Jon
242
