Bronze
EIGRP and static routes
I currently have a route that is known by EIGRP redistribution.
sh ip route 192.168.3.32
Routing entry for 192.168.3.32/27
Known via "eigrp 65204", distance 170, metric 63232, type external
Redistributing via eigrp 65204
Last update from 10.33.94.222 on GigabitEthernet1/4, 18:25:55 ago
Routing Descriptor Blocks:
* 10.33.94.222, from 10.33.94.222, 18:25:55 ago, via GigabitEthernet1/4
Route metric is 63232, traffic share count is 1
Total delay is 210 microseconds, minimum bandwidth is 44247 Kbit
Reliability 254/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
I'd like to add a static route to the same destination using a higher administrative distance.
ip route 192.168.3.32 255.255.255.224 10.10.11.149 220
This is to be used as a backup in case of the other route via EIGRP fails. Would this work?
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: EIGRP and static routes
Etienne
Yes it will work.
Jon
1 REPLY
Etienne
Yes it will work.
Jon
270
