EIGRP - ASA - DMZ Interface
Josh Edwards
Level 4
Level 4
Hello - I am trying to configure EIGRP on my ASA DMZ Interface - topology as follows:
Inside                        DMZ
3560x ------ ASA ------- 3560x
e0/1                          e0/3.501
The ASA is currently configured for EIGRP with the inside 3560x switch and passing routing updates properly.
However, the ASA will not send/receive routing updates to/from the DMZ 3560x switch - the two devices do establish eigrp neighbor relationship.
Any suggestions would be appreciated.
Thanks.
Josh
ASA Configuration:
router eigrp 600
no auto-summary
eigrp router-id 10.100.0.1
network 10.50.10.0 255.255.255.0
network NET-TOWER-TRANSIT-FW-10.100.0.0-24 255.255.255.0
passive-interface default
no passive-interface FW_TRANSIT
no passive-interface DMZ_TEST
redistribute static route-map EIGRP_REDISTRIBUTION_RMAP
interface Ethernet0/1
description Internal Tower Networks
nameif FW_TRANSIT
security-level 100
ip address 10.100.0.1 255.255.255.0
interface Ethernet0/3
description DMZ physical interface
nameif DMZ_PHYSICAL
security-level 50
no ip address
interface Ethernet0/3.510
vlan 510
nameif DMZ_TEST
security-level 50
ip address 10.50.10.254 255.255.255.0
DMZ Switch Configuration:
router eigrp 600
network 10.50.10.0 0.0.0.255
network 10.50.11.0 0.0.0.255
no passive-interface Vlan75
no passive-interface Vlan510
eigrp router-id 10.50.255.254
interface Vlan510
ip address 10.50.10.1 255.255.255.0
Sudeep Valengattil
Can you try adding "no auto-summary" in DMZ switch, to see if that resolves.
I'm not sure with ASA/firewalls. Hence not sure if I'm missing something on ASA side.
Hi Sudeep - thanks for the suggestion - no auto-summary is default on the version of IOS that I am running.
Josh Edwards
Level 4
Level 4
Some additional information - the neighbor relationship is flapping - it looks like the initial relationship is established but then each device is unable to pass on any update packets - below shows the Queue Count is non-zero.
on the ASA:
TOWER-FW01# sh eigrp ne
EIGRP-IPv4 neighbors for process 600
H     Address          Interface     Hold      Uptime     SRTT     RTO     Q     Seq
                                              (sec)                     (ms)                 Cnt   Num
1     10.50.10.1       Et0/3.510   11         00:01:14      1        5000    2      11184
0     10.100.0.253    Et0/1         11         9w0d           4       200      0       8357
on the 3560x:
TOWER-DMZ-01#sh ip eigrp ne
EIGRP-IPv4 Neighbors for AS(600)
                                              (sec)                    (ms)                 Cnt   Num
0     10.50.10.254    Vl510          14      00:00:18       1       5000     1      0
The ASA is also logging the following error:
Routing failed to locate next hop fro EIGRP from identity:10.50.10.254/0 to FW_TRANSIT:10.50.10.1/0
Another clue - when trying to ping from ASA to 3560x i receive the following:
TOWER-FW01# ping 10.50.10.1
Sending 5, 100-byte ICMP Echos to 10.50.10.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
I am able to ping from the 3560x to the ASA - I don't know why I cannot ping in the other direction
Josh Edwards
Level 4
Level 4
Issue is resolved in another post -
https://supportforums.cisco.com/message/3703561#3703561
