eigrp change neighbor metric
Hello
I have in the LAB hub ans spoke NBMA topology 1 hub and 2 spoke
and i was started EIGRP, HUB was push default route to the spokes.
i need some changes only in the HUB side what will be change neighbor metrik only one neighbor
if i change the interface on the HUB ( delay or bandwith ) this will be affect both spokes
i need change metric only in the one spoke
is it possible with EIGRP  ?
i can't found solution
Thank you
Hall of Fame Super Blue
Re: eigrp change neighbor metric
m.govorov wrote:
Hello
Thank you
Yes, you can use an offset-list which allows you to modify the metric on a per interface level -
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_eig2.html#wp1012264
Jon
Hello
but i have configured frame-relay in the physical interface so if i use offset-list it will change to both spoke
because both spokes was conected to one HUB serial interface
Thank you
m.govorov wrote:
Hello
Thank you
Ahh, then no you cannot do this. If you need to do this you will need to reconfigure your frame-relay to use subinterfaces and then you can apply the offset-list to the subinterface.
Jon
189
