EIGRP CONFIG
alsayed
Hello
check this Eigrp Config for the Attached Diagrams:
DS1
riuter eigrp 10
no auto-summary
Passive-interface Default
no Passive-interface int port-channel 0
network 100.100.100.1 0.0.0.0
network 10.10.10.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 100.100.100.5
DS2
riuter eigrp 10
no auto-summary
no Passive-interface int port-channel 1
network 100.100.100.2 0.0.0.0
ip route 0.0.0.0 0.0.0.0 100.100.100.1
IS THIS CONFIG WORK FINE...
10XS
6 Replies 6
azoulflak
The configuraion looks good but for the default route I think it is better in inject to EIGRP on the core router (ip default network or redistribute static..)
hello!
10xs for ur reply.plz give the Config on both Side?
10xs
hello Experts!
any clear reply Here
10xs
Kevin Dorrell
Level 10
Level 10
I can see a problem according to your diagram. Your DS1 has the line network 100.100.100.1 0.0.0.0. It should say network 100.100.100.6 0.0.0.0. 100.100.100.1 is on your core router, not on DS1.
Kevin Dorrell
Luxembourg
vanguardro
hello,
because we don't have your full configuration, i can guess about this
best way to do this is to create between DS1 & Core port-channel 1 and between DS2 & Core port-channel 2
for easy debuging, try to assign ip addresses from different networks to each port-channel
on Core on interface Port-Channel 1 use ip address 172.16.10.1 255.255.255.0
also on Core but on interface Port-channel 2 use ip address 172.16.20.1 255.255.255.0
on DS1 port-channel 1 use next ip address 172.16.10.10 255.255.255.0
and on DS2 port-channel 2 use ip address 172.16.20.10 255.255.255.0
next, our routing configuration
on Core:
router eigrp 10
no auto-summary
network 172.16.10.0 255.255.255.0
network 172.16.20.0 255.255.255.0
! also here you can inject your default route, or you can redistribute 0/0 from your table, is up to you
on router DS1:
router eigrp 10
no auto-summary
on router DS2:
router eigrp 10
no auto-summary
i hope this will be helpfully to you
vanguardro
10XS
