eigrp does not advertise external routes
I have got 2 switches facing to each other through an L3 etherchannel:
SW4(config-if)#do sh ip eigrp nei
EIGRP-IPv4 Neighbors for AS(10)
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
0   155.1.108.8             Po1               10 02:57:52    1   200  0  66
SW2(config-if)#do sh ip eig nei
EIGRP-IPv4:(10) neighbors for process 10
                                            (sec)         (ms)       Cnt Num
1   155.1.58.5              Vl58              11 02:36:13    9   200  0  72
0   155.1.108.10            Po1               12 02:58:52    1   200  0  36
The port channel is woking fine:
on SW2:
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(RU)          -        Fa0/19(P)   Fa0/20(P)
and on SW4:
1      Po1(RU)          -        Fa0/16(P)   Fa0/17(P)
SW2 receives eigrp external routes from Vlan 58:
SW2(config-if)#do sh ip route | i EX
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
D EX 204.12.1.0/24 [170/2560512512] via 155.1.58.5, 01:20:02, Vlan58
D EX    4.4.1.0 [170/2560512512] via 155.1.58.5, 01:20:02, Vlan58
D EX    4.4.2.0 [170/2560512512] via 155.1.58.5, 01:20:02, Vlan58
D EX    4.4.3.0 [170/2560512512] via 155.1.58.5, 01:20:02, Vlan58
D EX    31.3.0.0 [170/2560512512] via 155.1.58.5, 01:20:02, Vlan58
D EX    31.2.0.0 [170/2560512512] via 155.1.58.5, 01:20:02, Vlan58
D EX    31.1.0.0 [170/2560512512] via 155.1.58.5, 01:20:02, Vlan58
D EX    31.0.0.0 [170/2560512512] via 155.1.58.5, 01:20:02, Vlan58
D EX    30.2.0.0 [170/2560512512] via 155.1.58.5, 01:20:02, Vlan58
D EX    30.3.0.0 [170/2560512512] via 155.1.58.5, 01:20:02, Vlan58
D EX    30.0.0.0 [170/2560512512] via 155.1.58.5, 01:20:02, Vlan58
D EX    30.1.0.0 [170/2560512512] via 155.1.58.5, 01:20:02, Vlan58
This routing table matches what's in the eigrp topology:
SW2(config-if)#do sh ip eig top
EIGRP-IPv4 Topology Table for AS(10)/ID(150.1.8.8)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 155.1.5.0/24, 1 successors, FD is 28416
        via 155.1.58.5 (28416/28160), Vlan58
P 155.1.13.3/32, 1 successors, FD is 2682112
        via 155.1.58.5 (2682112/2681856), Vlan58
P 155.1.45.0/24, 1 successors, FD is 2170112
        via 155.1.58.5 (2170112/2169856), Vlan58
P 150.1.8.0/24, 1 successors, FD is 128256
        via Connected, Loopback0
P 30.3.0.0/16, 1 successors, FD is 2560512512
        via 155.1.58.5 (2560512512/2560512256), Vlan58
P 150.1.10.0/24, 1 successors, FD is 143360
        via 155.1.108.10 (143360/128256), Port-channel1
P 155.1.23.0/24, 1 successors, FD is 2682112
P 30.1.0.0/16, 1 successors, FD is 2560512512
P 155.1.108.0/24, 1 successors, FD is 15360
        via Connected, Port-channel1
P 4.4.2.0/24, 1 successors, FD is 2560512512
P 31.0.0.0/16, 1 successors, FD is 2560512512
P 31.3.0.0/16, 1 successors, FD is 2560512512
P 150.1.2.0/24, 1 successors, FD is 2298112
        via 155.1.58.5 (2298112/2297856), Vlan58
P 30.0.0.0/16, 1 successors, FD is 2560512512
P 204.12.1.0/24, 1 successors, FD is 2560512512
P 150.1.5.0/24, 1 successors, FD is 130816
        via 155.1.58.5 (130816/128256), Vlan58
P 155.1.13.1/32, 1 successors, FD is 21024256
        via 155.1.58.5 (21024256/21024000), Vlan58
P 155.1.8.0/24, 1 successors, FD is 2816
        via Connected, Vlan8
P 155.1.23.2/32, 1 successors, FD is 21024256
P 31.2.0.0/16, 1 successors, FD is 2560512512
P 192.10.1.0/24, 1 successors, FD is 2172672
        via 155.1.58.5 (2172672/2172416), Vlan58
P 155.1.10.0/24, 1 successors, FD is 15616
        via 155.1.108.10 (15616/2816), Port-channel1
P 31.1.0.0/16, 1 successors, FD is 2560512512
P 155.1.58.0/24, 1 successors, FD is 2816
        via Connected, Vlan58
P 155.1.23.3/32, 1 successors, FD is 2682112
P 155.1.45.4/32, 1 successors, FD is 2170112
P 4.4.1.0/24, 1 successors, FD is 2560512512
P 155.1.0.0/24, 1 successors, FD is 2170112
P 155.1.13.0/24, 1 successors, FD is 2682112
P 4.4.3.0/24, 1 successors, FD is 2560512512
P 30.2.0.0/16, 1 successors, FD is 2560512512
but external routes are not advertised to SW4:
SW4(config-if)#do sh ip route | i EX
Neither they are in the topology:
SW4(config-if)#do sh ip eigr topolo
EIGRP-IPv4 Topology Table for AS(10)/ID(150.1.4.4)
P 155.1.5.0/24, 1 successors, FD is 30976
        via 155.1.108.8 (30976/28416), Port-channel1
P 155.1.13.3/32, 1 successors, FD is 2684672
        via 155.1.108.8 (2684672/2682112), Port-channel1
P 155.1.45.0/24, 1 successors, FD is 2172672
        via 155.1.108.8 (2172672/2170112), Port-channel1
P 150.1.8.0/24, 1 successors, FD is 143360
        via 155.1.108.8 (143360/128256), Port-channel1
P 150.1.10.0/24, 1 successors, FD is 128256
P 155.1.23.0/24, 1 successors, FD is 2684672
P 150.1.2.0/24, 1 successors, FD is 2300672
        via 155.1.108.8 (2300672/2298112), Port-channel1
P 150.1.5.0/24, 1 successors, FD is 143616
        via 155.1.108.8 (143616/130816), Port-channel1
P 155.1.13.1/32, 1 successors, FD is 21026816
        via 155.1.108.8 (21026816/21024256), Port-channel1
P 155.1.8.0/24, 1 successors, FD is 15616
        via 155.1.108.8 (15616/2816), Port-channel1
P 155.1.23.2/32, 1 successors, FD is 21026816
P 192.10.1.0/24, 1 successors, FD is 2175232
        via 155.1.108.8 (2175232/2172672), Port-channel1
P 155.1.10.0/24, 1 successors, FD is 2816
        via Connected, Vlan10
P 155.1.58.0/24, 1 successors, FD is 15616
P 155.1.23.3/32, 1 successors, FD is 2684672
P 155.1.45.4/32, 1 successors, FD is 2172672
P 155.1.0.0/24, 1 successors, FD is 2172672
P 155.1.13.0/24, 1 successors, FD is 2684672
I removed Po1 and used a simple routed switchport instead (sw2-fa0/21 facing sw4-fa0/18), but the problem remains. I do not understand why. Furthermore, I have already used the same architecture and it was fine, all the external were advertised on SW4, but after quite a long time.
I have been told it was it's
I have been told it was it's a duplicate router-id issue:
Purple
Hi,SW2(config-if)#do sh ip
As you can see the EIGRP RIDs are different.
Can you issue following command on SW4: sh ip eigrp neigh detail  to see if SW2 is not a stub device
What is the model and image version for the switches ?
Alain
67
