EIGRP Flapping (retry limit exceeded) ???
asaykao73
Hi All,
This morning we're seeing EIGRP flap between 10.108.255.1 and 10.108.255.2 and nothing has changed on the network.
Topology:
[10.108.255.1(ASR)] --> [Nexus 5K] --> [3750] --> [10.108.255.2]
Logs on 10.108.255.1:
Mar  9 11:26:23.435 AEDT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 15: Neighbor 10.108.255.2 (Port-channel1.851) is down: retry limit exceeded
Mar  9 11:26:24.107 AEDT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 15: Neighbor 10.108.255.2 (Port-channel1.851) is up: new adjacency
Mar  9 11:27:43.610 AEDT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 15: Neighbor 10.108.255.2 (Port-channel1.851) is down: retry limit exceeded
Mar  9 11:27:43.730 AEDT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 15: Neighbor 10.108.255.2 (Port-channel1.851) is up: new adjacency
Mar  9 11:29:03.233 AEDT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 15: Neighbor 10.108.255.2 (Port-channel1.851) is down: retry limit exceeded
Mar  9 11:29:05.917 AEDT: %DUAL-5-NBRCHANGE: EIGRP-IPv4 15: Neighbor 10.108.255.2 (Port-channel1.851) is up: new adjacency
I've read through the various EIGRP troubleshooting guides online but can't narrow it down to what's causing this.
I believe it's a multicast issue somewhere within the network, but not sure how to diagnose where the issue is exactly.
1/ Unicast ping end-to-end works
From 10.108.255.1, we can ping 10.108.255.2 with small and large packet sizes.
Unfortuantely we don't have access to 10.108.255.2 so can't repeat the process the other way.
2/ Multicast ping fails
From 10.108.255.1, doing a multicast ping 224.0.0.10, we don't get any replies from 10.108.255.2 - so I think this is what the issue is.
My question is - how do I check where multicast is failing???
Config:
\\ 10.108.255.1
router eigrp 15
address-family ipv4 vrf Internal autonomous-system 15
  redistribute bgp 64655 metric 10000 100 255 1 1500
  network 10.108.255.0 0.0.0.3
  passive-interface default
  no passive-interface Port-channel1.851
encapsulation dot1Q 851
ip vrf forwarding Internal
ip address 10.108.255.1 255.255.255.252
no ip redirects
no ip unreachables
no ip route-cache
\\ 10.108.255.2
interface FastEthernet0/0
description Connects to 3750:Gi1/0/6
ip address 10.108.255.2 255.255.255.252
speed 100
full-duplex
router eigrp 15
redistribute static
redistribute ospf 80 metric 1000 10 255 1 1500
passive-interface Serial0/0.1
network 10.0.0.0
network 157.128.0.0
no auto-summary
eigrp log-neighbor-changes
\\ 3750
interface GigabitEthernet1/0/6
switchport access vlan 851
switchport mode access
load-interval 30
speed 100
duplex full
spanning-tree portfast
Thanks.
Andy
14 Replies 14
laureldj1
I had this problem using 3760 switches.  I found that the default for "system mtu routing" was 1998 in the IOS I was running.  Setting the value to 1500 solved the problem and upgrading the IOS resolved it permanently.
Hello
I would aggree check you mtu settings for the eigrp relationship
Also
access-list 100 permit ip host 10.108.255.1 host 224.0.0.10
debug ip packet detail 100
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Andy,
Can you run 'debug eigrp packets hello', and verify that multicast update packets are being send and or received on each end?
Andy, hi
did you resolve this problem
I have the same issue
Every 80 seconds EIGRP is DOWN
Dec 25 15:49:47: %DUAL-5-NBRCHANGE: EIGRP-IPv4 101: Neighbor 10.201.0.2 (POS3/0/0) is up: new adjacency
Dec 25 15:51:06: %DUAL-5-NBRCHANGE: EIGRP-IPv4 101: Neighbor 10.201.0.2 (POS3/0/0) is down: retry limit exceeded
Dec 25 15:51:07: %DUAL-5-NBRCHANGE: EIGRP-IPv4 101: Neighbor 10.201.0.2 (POS3/0/0) is up: new adjacency
Dec 25 15:52:26: %DUAL-5-NBRCHANGE: EIGRP-IPv4 101: Neighbor 10.201.0.2 (POS3/0/0) is down: retry limit exceeded
Dec 25 15:52:26: %DUAL-5-NBRCHANGE: EIGRP-IPv4 101: Neighbor 10.201.0.2 (POS3/0/0) is up: new adjacency
Dec 25 15:53:46: %DUAL-5-NBRCHANGE: EIGRP-IPv4 101: Neighbor 10.201.0.2 (POS3/0/0) is down: retry limit exceeded
I experienced EIGRP flapping between an 1841 ISR and an 3550 switch.  here is what made the flapping go away! " I added on the 3550 switch the following entry on my interface that my 1841 was trying to talk with:
"ip information-reply"
sw1#sh run int fa0/1
Building configuration...
Current configuration : 150 bytes
interface FastEthernet0/1
 description 1841_ISR
 no switchport
 ip address 10.0.0.2 255.255.255.0
 speed 10
 duplex half
end
EIGRP worked correctly following this change.  Hope it helps someone.
Yes thank you. one of my new switches had a system MTU set for jumbo frames and one of my other L3 switches wasnt able to connect because of this. I changed the interface by using ip mtu xxx.
chaitanya4u86
I faced this problem when running eigrp over DMVPN tunnel interface. Where the updates are flowing from hub to spoke but spoke is just sending Hellos to hub.
The actual problem is the MTU where I have set MTU to 1400 bytes considering the encryption along with GRE header, but only used GRE.
When I set the MTU to 1476 on both HUB and SPOKE, the issue is resolved.
Please note that this is a lab scenario with 7200 series routers running IOS: Version 15.0(1)M
DMVPN_HUB(config)#interface Tunnel0
DMVPN_HUB(config-if)#ip address 192.168.0.2 255.255.255.0
DMVPN_HUB(config-if)#ip mtu 1400
DMVPN_HUB(config-if)#ip nhrp authentication donttell
DMVPN_HUB(config-if)#ip nhrp map multicast dynamic
DMVPN_HUB(config-if)#ip nhrp network-id 99
DMVPN_HUB(config-if)#tunnel source FastEthernet1/0
DMVPN_HUB(config-if)#tunnel mode gre multipoint
DMVPN_HUB(config-if)#tunnel key 100000
*May 7 14:01:12.211: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.0.4 (Tunnel0) is down: retry limit exceeded
DMVPN_HUB#
*May 7 14:01:13.443: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.0.4 (Tunnel0) is up: new adjacency
DMVPN_HUB#
*May 7 14:02:32.963: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.0.4 (Tunnel0) is down: retry limit exceeded
DMVPN_HUB#
*May 7 14:02:36.307: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.0.4 (Tunnel0) is up: new adjacency
 DMVPN_HUB(config)#int tu0
DMVPN_HUB(config-if)#no ip mtu 1400
DMVPN_HUB(config-if)#ip mtu 1476
DMVPN_HUB#
*May 7 14:26:15.091: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.0.4 (Tunnel0) is up: new adjacency
DMVPN_HUB#show ip route eigrp
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is not set
1.0.0.0/32 is subnetted, 1 subnets
D 1.1.1.1 [90/156160] via 192.168.12.1, 00:13:49, FastEthernet0/0
3.0.0.0/32 is subnetted, 1 subnets
D 3.3.3.3 [90/27010560] via 192.168.0.4, 00:00:30, Tunnel0
4.0.0.0/32 is subnetted, 1 subnets
D 4.4.4.4 [90/27008000] via 192.168.0.4, 00:00:30, Tunnel0
D 192.168.34.0/24 [90/26882560] via 192.168.0.4, 00:00:30, Tunnel0
andre2mei
I got the same issue on my network. but I trying to disable auto-summary and the flapping is disappear.
I don't know what happen!
manoj.petshali
Hi all,
I faced this issue while doing DMVPN .
I got the messages as:
 12:22:06.906: %DUAL-5-NBRCHANGE: EIGRP-IPv4 45678: Neighbor  (Tunnel0) is down: retry limit exceeded
12:22:08.521: %DUAL-5-NBRCHANGE: EIGRP-IPv4 45678: Neighbor  (Tunnel0) is down: retry limit exceeded
This was the message at Hub side .
The solution worked was:
"no ip redirects    command on Hub side.
So here is a quick  solutions,
 if you are using  phase 1:
 enable   static multicast on the hub like :  ip  nhrp map multicast  nmba
you need to enable on the hub hub for each  spoke.
also try to ping 224.0.0.10 on all the side
Great, it solved my issue. thank you
mainkiller12
Hello ,
I have same issue with DMVPN,
I cannot ping the the tunnels ip and Lans are not talking each other through DMVPN.
HUB side config bellow:
sh version
Technology Package License Information:
Technology  Technology-package      Technology-package
       Current    Type      Next reboot
appxk9      None       None       None
uck9       uck9       Permanent    uck9
securityk9    None       None       None
ipbase      ipbasek9     Permanent    ipbasek9
cisco ISR4331/K9 (1RU) processor with 1795999K/6147K bytes of memory.
interface Tunnel35
 description #### DMVPN ####
 ip address 172.16.100.1 255.255.255.0
 no ip redirects
 ip mtu 1476
 no ip next-hop-self eigrp 100
 no ip split-horizon eigrp 100
 ip nhrp authentication cisco123
 ip nhrp network-id 35
 ip nhrp holdtime 60
 ip nhrp registration timeout 30
 ip tcp adjust-mss 1360
 keepalive 2 3
 tunnel source GigabitEthernet0/0/0
 tunnel key 1234
interface GigabitEthernet0/0/0
 description ## ISP##
 ip address 105.174.37.242 255.255.255.248
 ip nat outside
 negotiation auto
 ip virtual-reassembly
interface GigabitEthernet0/0/1
 description ## LAN ##
 no ip address
 ip nat inside
 negotiation auto
interface GigabitEthernet0/0/1.10
 description ## data##
 encapsulation dot1Q 10
 ip address 192.168.10.1 255.255.255.0
 ip nat inside
router eigrp 100
 network 172.16.0.0
 network 192.168.0.0
ip route 0.0.0.0 0.0.0.0 105.174.37.241
sh ip eigrp neighbors
EIGRP-IPv4 Neighbors for AS(100)
H  Address         Interface       Hold Uptime  SRTT  RTO Q Seq
                          (sec)     (ms)    Cnt Num
0  172.16.100.2      Tu35           10 00:01:08  1 5000 1 0
*Nov 6 10:47:12.075: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.16.100.2 (Tunnel35) is down: retry limit exceeded
*Nov 6 10:47:15.449: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.16.100.2 (Tunnel35) is up: new adjacency
On SPOKE side
SH VERSION
cisco ISR4321/K9 (1RU) processor with 1795999K/6147K bytes of memory.
interface Tunnel35
 ip address 172.16.100.2 255.255.255.0
 no ip redirects
 ip mtu 1476
 ip nhrp map multicast 105.174.37.242
 ip nhrp map 172.16.100.1 105.174.37.242
 ip nhrp nhs 172.16.100.1
 tunnel source GigabitEthernet0/0/1
 tunnel key 1234
 no ip address
 negotiation auto
interface GigabitEthernet0/0/0.30
 description ## data ##
 encapsulation dot1Q 30
 ip address 192.168.30.1 255.255.255.0
 ip nat inside
router eigrp 100
 network 105.0.0.0
 network 172.16.0.0
 network 192.168.0.0
 redistribute static
Not able to ping 172.16.100.1 on the HUB
Can some one please help!
rifi1
Please enable multicast on your HUB:
It happened to me in an EIGRP lab. The problem was different masks on the interface . One had a /24 and one was /30. So every couple of seconds eigrp would create an adjacency and then drop it .
