06-30-2010 08:32 AM - edited 03-06-2019 11:50 AM
I have an issue I am trying to understand with EIGRP not accepting or not using routes advertised from an EIGRP neighbor. Router A is directly connected to Router B, and both have established eigrp neighbor relationship with one another. When displaying IP PROTOCOL, Router A does not list Router B as a Routing Information Source, but Router B does show Router A as a Routing Information Resource. Router B has 5 directly connected networks it is advertising to Router A, but Router A will not put the networks in it's routing table, nor are they in the topology table. What would cause this? Below are snipets from the two routers:
Router A
interface Multilink203386
ip address 10.250.241.66 255.255.255.252
ip route-cache flow
delay 20
ppp multilink
ppp multilink group 203386
max-reserved-bandwidth 100
service-policy output UDN-EDGE
router eigrp 2013
network 10.0.0.0
auto-summary
IP-EIGRP neighbors for process 2013
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
7 10.250.241.65 Mu203386 12 14:14:54 1 200 0 1532
6 10.250.170.154 Mu205680 12 6w3d 3 200 0 83199
4 10.250.170.106 Se1/3:0 13 6w3d 6 200 0 584572
5 10.250.170.114 Mu204840 14 10w1d 1 200 0 1505421
1 10.250.100.93 Se6/1 11 14w3d 1 200 0 4207627
8 10.250.170.217 Hs5/0 11 14w4d 5 200 0 346884
0 10.250.170.202 Se6/0 12 15w2d 1 200 0 2246571
2 10.250.110.53 Se3/0 11 17w5d 1 200 0 5440745
3 10.250.170.133 Se3/1 10 40w2d 1 200 0 2682260
sh ip protocols
Routing Information Sources:
Gateway Distance Last Update
10.250.170.114 90 00:10:58
10.250.170.106 90 00:10:58
10.250.170.217 90 00:10:58
10.250.170.202 90 00:10:58
10.250.110.53 90 00:10:58
10.250.170.154 90 00:10:58
10.250.100.93 90 00:10:58
10.250.170.150 90 10w4d
10.250.170.133 90 00:10:58
Router B
ip address 10.250.241.65 255.255.255.252
delay 20
ppp multilink
router eigrp 2013
network 10.0.0.0
auto-summary
(sec) (ms) Cnt Num
5 10.168.1.10 Gi1/0.300 13 14:20:02 1 200 0 61786
4 10.250.130.69 Se0/0/0:0 12 14:20:02 4 200 0 531447
3 10.250.241.66 Mu203386 14 14:20:02 1 200 0 3056950
2 10.168.1.11 Gi1/0.300 13 14:20:02 1 200 0 61189
1 10.168.1.9 Gi1/0.300 10 14:20:02 2 200 0 61342
0 10.168.1.3 Gi1/0.300 13 14:20:02 1 200 0 53499
sh ip protocols
10.250.130.69 90 00:01:49
10.250.241.66 90 00:01:49
10.168.1.3 90 00:01:50
10.168.1.11 90 00:01:50
10.168.1.10 90 00:01:50
10.168.1.9 90 00:01:50
Solved! Go to Solution.
06-30-2010 06:53 PM
show output of ip protocols is in my original post.
06-30-2010 07:01 PM
Your original post contained highly abreviated output from show ip protocol. I would like to see the complete output of show ip protocol.
And as I think about it I would also ask that you post the output of show ip eigrp neighbor detail from both routers.
Rick
07-01-2010 08:05 AM
Below are the ip porotocols and neighbor details you asked for. Last night I tried to force Router A to accept the routes from Router B by using a distribution-list on Router B's other outbound interface to stop one of the internal routes (10.168.2.253/32). Router A lost the route to that network but still would not install the route from Router B. Wonder if I am looking at a bug.
Router A
sh ip proto
Routing Protocol is "eigrp 2013"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Default networks flagged in outgoing updates
Default networks accepted from incoming updates
EIGRP metric weight K1=1, K2=0, K3=1, K4=0, K5=0
EIGRP maximum hopcount 100
EIGRP maximum metric variance 1
Redistributing: eigrp 2013
EIGRP NSF-aware route hold timer is 240s
Automatic network summarization is in effect
Maximum path: 4
Routing for Networks:
10.0.0.0
10.250.170.114 90 00:20:16
10.250.170.106 90 00:20:15
10.250.170.217 90 00:20:15
10.250.170.202 90 00:20:16
10.250.110.53 90 00:20:15
10.250.170.154 90 00:20:16
10.250.100.93 90 00:20:15
10.250.170.150 90 10w5d
10.250.170.133 90 00:20:15
Distance: internal 90 external 170
sh ip eigrp nei det
(sec) (ms) Cnt Num
7 10.250.241.65 Mu203386 12 17:40:57 1 200 0 4679
Version 12.4/1.2, Retrans: 0, Retries: 0
6 10.250.170.154 Mu205680 13 6w4d 1 200 0 84450
Version 12.4/1.2, Retrans: 1, Retries: 0, Prefixes: 37
4 10.250.170.106 Se1/3:0 11 6w4d 6 200 0 586698
Version 12.4/1.2, Retrans: 0, Retries: 0, Prefixes: 2125
5 10.250.170.114 Mu204840 11 10w2d 2 200 0 1507185
Version 12.4/1.2, Retrans: 15, Retries: 0, Prefixes: 36
1 10.250.100.93 Se6/1 12 14w4d 1 200 0 4213915
Version 12.2/1.2, Retrans: 3, Retries: 0, Prefixes: 1988
8 10.250.170.217 Hs5/0 12 14w5d 5 200 0 349231
Version 12.2/1.2, Retrans: 4, Retries: 0, Prefixes: 1071
0 10.250.170.202 Se6/0 10 15w3d 1 200 0 2249060
Version 12.4/1.2, Retrans: 5, Retries: 0, Prefixes: 40
2 10.250.110.53 Se3/0 13 17w6d 1 200 0 5447192
Version 12.2/1.2, Retrans: 1, Retries: 0, Prefixes: 1999
3 10.250.170.133 Se3/1 13 40w3d 1 200 0 2685439
Version 12.4/1.2, Retrans: 119, Retries: 0, Prefixes: 2005
Router B
sh ip prot
Maximum path: 4
10.0.0.0
Passive Interface(s):
GigabitEthernet0/0
GigabitEthernet0/1
Serial0/0/1:0
Serial0/1/0:0
GigabitEthernet1/0
GigabitEthernet1/0.50
GigabitEthernet1/0.66
GigabitEthernet1/0.298
Loopback256
VoIP-Null0
10.250.130.69 90 00:21:16
10.250.241.66 90 00:21:16
10.168.1.3 90 00:21:16
10.168.1.11 90 00:21:16
10.168.1.10 90 00:21:16
10.168.1.9 90 00:21:16
sh ip eigrp nei det
(sec) (ms) Cnt Num
3 10.250.241.66 Mu203386 13 17:41:58 1 200 0 3060402
Version 12.4/1.2, Retrans: 0, Retries: 0, Prefixes: 2122
5 10.168.1.3 Gi1/0.300 10 18:13:11 1 200 0 894
Version 12.4/1.2, Retrans: 2, Retries: 0, Prefixes: 5
0 10.168.1.10 Gi1/0.300 14 18:13:15 1 200 0 968
Version 12.4/1.2, Retrans: 2, Retries: 0, Prefixes: 1
4 10.250.130.69 Se0/0/0:0 11 1d13h 1 200 0 533773
Restart time 13:28:08
Version 12.4/1.2, Retrans: 0, Retries: 0, Prefixes: 2112
2 10.168.1.11 Gi1/0.300 10 1d13h 1 200 0 62585
Version 12.4/1.2, Retrans: 6, Retries: 0, Prefixes: 1
1 10.168.1.9 Gi1/0.300 14 1d13h 2 200 0 62744
Version 12.4/1.2, Retrans: 7, Retries: 0, Prefixes: 1
07-01-2010 05:45 PM
Thanks for the additional information. I do not see anything that explains why the problem is happening.
I do not know if another attempt to clear the neighbor and then show ip eigrp event trying to get the display of events at the moment of the clearing would show anything useful. But it might be worth a try.
I would also suggest that it might be worth doing an interface shutdown/no shutdown on the multilink on router A. I have seen some situations where a routing protocol got confused or otherwise out of sync with its neighbor and a shut/no shut cleared it up. And the ultimate extension of that would be to schedule a reload of the router.
Since we are not making good progress in resolving this it might also be time to be thinking about opening a Cisco TAC case. Are these routers covered under maintenance?
Rick
07-01-2010 05:51 PM
I did open a TAC earlier today. At this point I am going to wait for Cisco to respond. Rebooting of the router is going to require an outage request, scheduled two weeks out.
07-01-2010 09:43 PM
I recognize that planning for a reload may require planning and effort (and administrative overhead) which produce delay. I only lay it out as one of the possibilities to consider.
Opening a case with TAC was a good thing. When you get a response or when you have found a solution to the problem please post back to the forum and update us. We would very much like to know how this turns out.
Rick
07-02-2010 07:51 AM
I will definately update the forum when the solution is found. Appreciate your time
on this.
07-02-2010 01:18 PM
The problem has been resolved, though I still don't know what caused it. I pulled one of the t1 from the ppp link, gave it an ip address, and established an eigrp neighbor relation over the link. This immediately saw proper routing as it now had a better metric. I then blew away the mlppp configuration and rebuilt it. Once I removed the ip address from the t1 and put it back into the ppp link, we saw Router A accepting routes from Router B.
07-03-2010 11:04 AM
I am glad that you have got the problem resolved. Thanks for posting back to the forum about it. Perhaps you could mark the question as solved. This would benefit other people who might read the thread to find out about the problem and about its solution.
Your solution of removing and rebuilding the multilink configuration is a stronger action but similar to my suggestion about interface shutdown/no shutdown. As I commented in a previous post I have seen situations where a routing protocol got confused or out of sync about a neighbor (sometimes it seems related to a configuration change made and then removed where the protocol seems to be remembering the change even though it is no longer in the running config, and sometimes we never had a clue what caused it) and terminating and rebuilding the neighbor relationship would solve the issue.
So congratulations on getting your problem resolved.
Rick
