Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Eigrp routing issue
we have two routes for one of the destination. But i am not able to see one route in my topology table., what might be the cause.Thanks in advance.
Routing protocol : Eigrp
Hall of Fame Super Blue
Re: Eigrp routing issue
arun@fuzzy15s.com
Could you be more specific.
Do you mean you have 2 equal cost path routes but you are only seeing one in the routing table
OR
do you mean you have 2 routes to a destination but when you look at the topology table you only see on route. If so are you using the command "sh ip eigrp topoology all-links" because without the all-links you will only see the successor and feasible successor routes.
Jon
yes, i have 2 routes to a destination but when i look at the topology table i can see only one route...
What command are you using to look at the topology table ?
Jon
sh ip eigrp top xx.xx.xx.xx mask
arun@fuzzy15s.com
Could you read my original post about "sh ip eigrp topology all-links"
Jon
Jon
Hi Jon,
I am not sure if this is IOS specific but on most of the IOS versions that I have tried the 'show ip eigrp topo ' displays all the routes not just the feasible successor. I believe the "show ip eigrp top all-links" command is equal to the "show ip eigpr top" without specifying the actual network and mask. Appreciate if you can can confirm if you know otherwise as I have always used the show ip eigrp top to troubleshoot such scenarios. thx for your help.
Hi jon,
The route is not available only for particular destination , I can see it in sh ip eigrp top
vdadlaney wrote:
Jon
Hi Jon,
Must admit from memory i thought that only the all-links and detail-links options showed all routes learnt via EIGRP. You've got me thinking now so i'll have to lab it up and get back to you
Jon
269
