Bronze
Emergency help - Sup 720 & Sup 720-3B
I hope this can be done. We have a Cat 6500 with a Sup 720 (PFC-3a) that is starting to show signs of failure. Show module is already reporting that it has failed, but is only now starting to cause problems.
I have only a single Sup 720 (w/ PFC-3a) installed in the chassis. My question - I have a Sup 720-3B sitting in the box. Can I just pop this module in and will it interoperate with the PFC-3a? My hope is that I can simply pop it in, sync the config and then remove the bad sup for repair.
Anyone?
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Emergency help - Sup 720 & Sup 720-3B
Jim
Unfortunately you can't do this. The PFCx and MSFCx versions must be identical in each supervisor -
"Likewise, the PFCx and MSFCx versions must match on the active and standby Supervisor Engine 720 or Supervisor Engine 32"
Full link -
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper09186a0080088874.html
Jon
Jim
Full link -
Jon
Bronze
Thank you for your help, Jon.
I'll just have to wait for the replacement part from Cisco TAC.
245
