Silver
enable jumbo frame on Catalyst 6513
Hi all,
If I have Ether-channel on the Catalyst 6513 and that I want to enable jumbo frame
on the ports that are belong to the
Ether- channel port-channel. Do I need to enable jumbo frame on the physical
ports itself or just the port-channel?
According to Cisco, I only need to do it
on the port-channel, is that correct?
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/sw_int.html#wp1053326
1 REPLY
Re: enable jumbo frame on Catalyst 6513
You can use this feature on trunking/channeled or regular port, and on the physical port.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml#intro
1086
