11-19-2006 11:49 PM - edited 03-05-2019 12:55 PM
is it possible to enable inter-vlan rouitng on cisco switch 2970 i tried but fiald
Solved! Go to Solution.
11-20-2006 12:17 AM
hi sadam,
since 2970 is a layer 2 switch, you won't find "ip routing" command on to it.
11-19-2006 11:56 PM
cisco 2970 is Layer 2 Managed Ethernet Switch.
since it is not a layer 3 switch, it is not possible to configure inter-vlan routing on it.
rate if it helps ...
11-20-2006 12:17 AM
hi sadam,
11-20-2006 12:18 AM
Hi friend,
As posted earlier the 2970 is a layer 2 switch and hence does not support inter vlan routing.
You should consider using a 3550,3560,3750 or
above for inter vlan routing
Narayan
