enable secret overwrite vty telnet password? (Cat 4500)
I face some funny situation on changing the local password of the switch.
Let me show you 2 switches result - one nornal, one abnormal.
For a normal situation, a switch - pg71scr-as01, if I configure
service password-encryption
enable password a1t3router
enable secret william
line vty 0 4
password cisco
line con 0
password cisco
In such case, my telnet login password is still cisco, but my priviledge password will be william, because of secret password will override enable password.
Now, I have an abnormal switch - pg71scc1-as03, if I configure
line vty 0 4
password cisco
line con 0
password cisco
My telnet login password will be william, and my priviledge password will be william too. Why???
Now, let us compare the version and modules of this 2 switches:
Normal Switch - pg71scr-as01
pg71scr-as01#sh mod
Chassis Type : WS-C4506
Power consumed by backplane : 10 Watts
Mod Ports Card Type Model Serial No.
1 2 1000BaseX (GBIC) Supervisor(active) WS-X4013+ JAE********
2 6 1000BaseX (GBIC) WS-X4306-GB JAE********
3 48 10/100BaseTX (RJ45) WS-X4148-RJ JAF********
4 48 10/100BaseTX (RJ45) WS-X4148-RJ JAF********
5 48 10/100BaseTX (RJ45) WS-X4148-RJ JAF********
6 48 10/100BaseTX (RJ45) WS-X4148-RJ JAF********
pg71scr-as01#sh ver
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9K2S-M), Version 12.1(20)EW2
, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 12.1(20r)EW1
Dagobah Revision 86, Swamp Revision 3
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication enable default group tacacs+ enable
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default stop-only group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa accounting system default start-stop group tacacs+
Abnormal switch - pg71scc1-as03
pg71scc1-as03#sh mod
3 48 10/100BaseTX (RJ45) WS-X4148-RJ JAE********
4 48 10/100BaseTX (RJ45) WS-X4148-RJ JAE********
pg71scc1-as03#sh ver
ROM: 12.1(20r)EW1
aaa new-model
aaa authentication login default group tacacs+ enable
I don't see any different on the hardware. Same part number, same firmware, same IOS image. They are also having same aaa configuration and boot parameter. Can you help to check it out?
Thanks.
Re: enable secret overwrite vty telnet password? (Cat 4500)
Enable secret has precedence over enable password.
Enable secret *** will overide the existing enable password.
Purple
Don't know , don't see how your vty password can be william and not cisco . How are you testing this are you pulling the tacacs server statement ?
Hall of Fame Super Silver
There is actually a simple explanation of why this is happening. It is that the switches are configured differently in one significant detail. Here is the config given in an earlier post:
normal switch:
aaa new-model
both switches will attempt to authenticate a login request with TACACS. If there is no response from TACACS the first switch uses the line password to authenticate but the second switch will use enable to authenticate the login request. If you want the second switch to use the line password then change the aaa authentication command.
Rick
1982
