I've been working for weeks to enable sending traps for FIB changes on our Cisco 2600 router. I finally found this command is responsible for that:
snmp-server enable traps cef peer-fib-state-change
But it seemed Cisco 2600 does not accept the "cef" command. After retrieving the whole trap options that can be enabled, we found the following list is all traps which are supported. We found none of them is actually directly enabling FIB changes, however some of them looked relevant, such as entity. Is there any ways to infer FIB changes on any of these options?
atm Enable SNMP atm traps
bgp Enable BGP state change traps
bstun Enable SNMP BSTUN traps
cnpd Enable NBAR Protocol Discovery traps
config Enable SNMP config traps
config-copy Enable SNMP config-copy traps
dial Enable SNMP dial control traps
dlsw Enable SNMP dlsw traps
dnis Enable SNMP DNIS traps
dsp Enable SNMP dsp traps
entity Enable SNMP entity traps
envmon Enable SNMP environmental monitor traps
frame-relay Enable SNMP frame-relay traps
hsrp Enable SNMP HSRP traps
ipmobile Enable SNMP ipmobile traps
ipmulticast Enable SNMP ipmulticast traps
ipsec Enable IPsec traps
isakmp Enable ISAKMP traps traps
isdn Enable SNMP isdn traps
msdp Enable SNMP MSDP traps
pim Enable SNMP PIM traps
pppoe Enable SNMP pppoe traps
rsvp Enable RSVP flow change traps
rtr Enable SNMP Response Time Reporter traps
snmp Enable SNMP traps
stun Enable SNMP STUN traps
syslog Enable SNMP syslog traps
tty Enable TCP connection traps
voice Enable SNMP voice traps
vtp Enable SNMP VTP traps
xgcp Enable XGCP protocol traps
