Webcast-Catalyst9k
enabling CEF changing connected routes to static route
I have 3800 router which has ospf for LAN and static. we are redistributing static routes into ospf. when enabling local gig interface which was showing connected become static route. we routing local subnet also to serial interfaces. but local interface should be showing connected. Please provide me a solution on this.
Re: enabling CEF changing connected routes to static route
If we disable cef everything working fine.
If anyone knows the reason, please help me.
Sampath,
Could you please provide the output of a "show ip route x.x.x.x" for the specific route and "show int xx" for the specific int.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Router2#sh ip route 1.1.1.3
Routing entry for 1.0.0.0/8
Known via "static", distance 1, metric 0
Redistributing via ospf 1
Advertised by ospf 1 subnets
Routing Descriptor Blocks:
* 172.16.1.2
Route metric is 0, traffic share count is 1
We have route 1.0.0.0 255.255.255.0 to 172.16.1.2
statis routes redistributed into ospf. It usually shows connected when no ip cef. When CEF enabled showing static.
i think has something to do with the way that CEF maintains the FIB database, cant explain further though.
on the neighbor routers with CEF enabled,do you see the same route as ospf route?
Yes. i am seeing this route through ospf.
Sampath,
Can you provide the exact configuration of the static route and the version of IOS you use.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
interface GigabitEthernet0/0
ip address 1.1.1.3 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
ip virtual-reassembly
no ip mroute-cache
ip ospf authentication message-digest
ip ospf authentication-key
duplex auto
speed auto
media-type rj45
no cdp enable
router ospf 1
router-id 1.1.1.3
log-adjacency-changes
redistribute static subnets
passive-interface default
no passive-interface GigabitEthernet0/0
no passive-interface GigabitEthernet0/1
ip route 0.0.0.0 0.0.0.0 1.1.1.254 (customer FW)
ip route 10.0.0.0 255.0.0.0 172.16.1.2
IOS version : c3845-advsecurityk9-mz.124-15.XY1.bin
OSPF used in LAN environment for redundancy.
Route wrongly mentioned
ip route 1.0.0.0 255.0.0.0 172.16.1.2 is the correct one.
Any help on this?
164
