Enabling EHWIC card in 3925 router
We have a Cisco 3925 router with an EHWIC-4ESG card running on IOS image c3900-universalk9-mz.SPA.150-1.M2.bin.  A show diag shows this card as disabled/not supported.  Needing assistance to determine if the IOS code installed is the reason for the card not being supported or if other configuration settings are needed.
VIP Super Bronze
Re: Enabling EHWIC card in 3925 router
May be a license issue.
Do you have IP Base license installed on the 3925?
Bronze
I believe you need 15.1(2)T or higher code to support the card
675
