enabling IPv6 on VSS
I'm trying to set up IPv6 on my Virtual Switch.
I can set IPv6 addresses, can ping from the switch to the next hop and also to the internet.
I set up a VLAN with IPv6 but clients connected to this VLAN don't receive any advertisements from the router.
If I read the docu, I should use the global command ipv6 unicast-routing to enable IPv6. But this command is not available.
IOS Version is (s72033_rp-IPBASEK9-M), Version 12.2(33)SXI3
Any ideas?
Thanks in advance
Thomas
Everyone's tags (2)
Re: enabling IPv6 on VSS
Hello Thomas,
I wonder if the full IPv6 routing support is available in your image. You are currently running the IP Base feature set. Although the Feature Navigator insists that your image should support IPv6 routing, I have a feeling that your image actually supports only IPv6 end host functions.
Also please see this article:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_bulletin_c25_542214_ps6553_Products_Bulletin.html
It may be necessary to upgrade to IP Services. Nevertheless, I do not have hands-on experience with the VSS so please consider this information as a suggestion, not as an assured solution. I would be glad if someone with better experience on VSS voiced his/her opinion here.
Best regards,
Peter
There seems to be a misconfiguration in the Software Advisor.
If you want to use IPv6 unicast routing on a VSS you need at least IP Services feature set.
Thomas
537
