enabling irb on a 7606 router
Hi, I have a 7606 router running with the IOS 12.2(33) Advservices WAN.
The issue is that I can't create a bvi or a bridge group. The supported protocols for STP are ibm, dec and vlan-bridge. ieee is also missing.
Under a serial interface, I can't enter the command 'bridge-group x' or create a bvi at all. Is the issue IOS related? or Is it 7600 series specific problem?
Thanks in advance, OC.
1 REPLY
Purple
Re: enabling irb on a 7606 router
The code doesn't support it . I would check the feature navigator and see if there is a version that supports it .
158
