enabling rsh on 6509 for catos
I have a 6509 running 8.5(5) CATOS and am wondering how to enable rsh so that I can issue CATOS commands. I have found information for the IOS but got "connection refused" response. The IOS commands I used were
username root privilege 15
ip rcmd rsh-enable
ip rcmd remote-host root 172.25.100.160 root
[dummy ~]$ rsh -l root 10.0.0.4 "show version"
10.0.0.4: Connection refused
Thanks.
Re: enabling rsh on 6509 for catos
Add the following lines and give it another shot:
username root password {password}
ip rcmp remote-username root
replace {password} with your password of choice.
Please rate if this helps
Hi med_ddevlin,
I implemented your suggestion, but still get connection refused.
Best regards.
what happens when you enter:
rsh -l root 10.0.0.4 sh ver
Does that work at all?
You are sourcing from 172.25.100.160 correct?
222
