Enabling ssl on 3560g
Does anyone know how you enble port 443 on a 3560g switch/router?
Gary
Re: Enabling ssl on 3560g
If you have configured any acces lists then it must be allowed by default and if you have implemented any access then, you can write an access list and allow the port 443 for source to destination ips. You can check the below link.
http://safariexamples.informit.com/1587200554/content/8-538.pdf
Suresh Jain
Hi gary,
If you are asking how to enable HTTPS on the switch, then the commands are as follows
Ip http secure-server
ip http authentication local
username admin privelege 15 secret
HTTPS is opened by default on all the new switches and routers.
Narayan
255
