11-28-2006 05:29 AM - edited 03-05-2019 01:03 PM
Guys,
Is the EOBC0/0 respsonible for the 1 "connected" network in the output of the "show ip route summary command" and this would appear on all 6500 routing architectures?, ie sup720s MSFC etc etc
6500>sh ip route conn
C 127.0.0.0/8 is directly connected, EOBC0/0
text omiited...........
6500>sh ip route summ
IP routing table name is Default-IP-Routing-Table(0)
Route Source Networks Subnets Overhead Memory (bytes)
connected 1 11 768 1824
static 0 36 2304 5472
Many thx indeed,
Ken
12-04-2006 07:33 AM
On Catalyst 5000 ATM modules, this will display as "1 Ethernet/IEEE 802.3 interface(s)" from show version and "Ethernet0" from show interface. On lower WS-X6101 IOS versions, this interface is displayed as EOBC0 (Ethernet Out of Band Channel) interface from the show interface command. Higher Cisco IOS versions, such as 12.1.13E, no longer display this EOBC0 from the show interface command. A show eobc command is available to display its status. This command is only introduced on Catalyst 6000.
12-04-2006 08:05 AM
Usually you don't see this network, but it is always used to connect from SP to MSFC under CatOS:
SP# session 15
MSFC#who
Line User Host(s) Idle Location
* 1 vty 0 idle 00:00:00 127.0.0.51
