10-15-2006 04:24 AM - edited 03-05-2019 12:15 PM
Hello all
I have done somthing very stupid!! I got the idea to clean up all old configs and start over again.
I found documentations how to clear bootflash, and didnt know that it was removing the boot image.
Now i get the output:
device does not contain a valid magic number
boot: cannot open "bootflash:"
boot: cannot determine first file name on device "bootflash:"
I'm trying to use xmodem -y -s 57600:
Do not start sending the image yet...
Invoke this application for disaster recovery.
Do you wish to continue? y/n [n]: y
Note, if the console port is attached to a modem, both the
console port and the modem must be operating at the same baud
rate. Use console speed 57600 bps for download [confirm]
Download will be performed at 57600. Make sure your terminal
emulator is set to this speed before sending file.
Ready to receive file ...
xxxxxxxxxx................lots of funny chars................
- Then its stops! What can i do ??
10-15-2006 04:31 AM
Hi Dan,
Just go thro. this document which gives step by step procedure,
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
Rate if it does,
Rgs
10-15-2006 04:34 AM
If there is a mismatch in the terminal emulator Speed and the speed configured on the console port, it will result in junk characters
Check this link for more details
HTh, rate if it does
Narayan
