Erase of bootflash: 2948G-L3
Hello all
I have done somthing very stupid!! I got the idea to clean up all old configs and start over again.
I found documentations how to clear bootflash, and didnt know that it was removing the boot image.
Now i get the output:
device does not contain a valid magic number
boot: cannot open "bootflash:"
boot: cannot determine first file name on device "bootflash:"
I'm trying to use xmodem -y -s 57600:
Do not start sending the image yet...
Invoke this application for disaster recovery.
Do you wish to continue? y/n [n]: y
Note, if the console port is attached to a modem, both the
console port and the modem must be operating at the same baud
rate. Use console speed 57600 bps for download [confirm]
Download will be performed at 57600. Make sure your terminal
emulator is set to this speed before sending file.
Ready to receive file ...
xxxxxxxxxx................lots of funny chars................
- Then its stops! What can i do ??
Silver
Re: Erase of bootflash: 2948G-L3
Hi Dan,
Just go thro. this document which gives step by step procedure,
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
Rate if it does,
Rgs
If there is a mismatch in the terminal emulator Speed and the speed configured on the console port, it will result in junk characters
Check this link for more details
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_guide_chapter09186a0080136ced.html#xtocid2341214
HTh, rate if it does
Narayan
447
