05-06-2007 06:02 PM - edited 03-05-2019 03:54 PM
Greetings! I have a question that I hope someone is able to accurately answer. The question is:
What colour does the LED go when a Cisco switch 2950 goes into Err-disabled mode?
Thank you in advance for all your help.
Kind regards,
Ashraf.
Solved! Go to Solution.
05-06-2007 06:29 PM
Hello Ashraf
The port will be on orange colour when err-disabled... you can do a manual no shut to the port to bring it up.. you can find more details on err-disable feature in the following URL:
http://cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00806cd87b.shtml
Hope this helps.. all the best..
Raj
05-06-2007 06:29 PM
Hello Ashraf
Raj
05-06-2007 07:35 PM
Dear Raj,
Thank you very much for your help! I very much appreciate your kindness.
Hope all is well with you.
Kind regards,
Ashraf.
