Community Member
errdiasble recovery interval recommnedation
Is there a minimum recommended value for the errdiasble recovery interval?
I know that the default is 300 seconds. Is there a valid reason to decrease that interval. Are there any whitepapers available that discuss the impact of shortening it?
I came across the following set of commands within a configuration template that is being used for any new switch deployments:
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery interval 50
No one can explain why the interval was reduced to 50 seconds nor how would impact the network.
1 REPLY
Purple
Re: errdiasble recovery interval recommnedation
The simple answer whoever decided they did not want to wait very long to try and renenable the port if a port goes down errdisable . at 50 seconds if the port really has a problem then you are going to get a fair amount of spanning tree churn which could possibly disrupt things seeing that normal spanning tree takes almost that long to run .
165
