Errdisable Port State Recovery
All,
I am testing 2960 24 S  with storm-control  and Errdisable Port timer interval 60s , connected HUB on fa0/17 to make traffic / loop
After Strom Control detection the interface goes down thats ok  after 60s they will try to recover the interface and going up although the loop is still there.
For my understanding if the interface detect still a loop on that interface they will disable the port again for 60s and will check  again
any idea ?
00:55:10: %PM-4-ERR_DISABLE: storm-control error detected on Fa0/17, putting Fa0/17 in err-disable state
00:55:10: %STORM_CONTROL-3-SHUTDOWN: A packet storm was detected on Fa0/17. The interface has been disabled.
00:55:10: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
00:55:11: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/17, changed state to down
00:55:12: %LINK-3-UPDOWN: Interface FastEthernet0/17, changed state to down
00:56:10: %PM-4-ERR_RECOVER: Attempting to recover from storm-control err-disable state on Fa0/17
00:56:11: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
00:56:13: %LINK-3-UPDOWN: Interface FastEthernet0/17, changed state to up
00:56:14: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/17, changed state to up
OB#sh errdisable recovery
ErrDisable Reason            Timer Status
bpduguard                    Disabled
channel-misconfig (STP)      Disabled
dhcp-rate-limit              Disabled
dtp-flap                     Disabled
gbic-invalid                 Disabled
inline-power                 Disabled
link-flap                    Disabled
mac-limit                    Disabled
loopback                     Disabled
pagp-flap                    Disabled
port-mode-failure            Disabled
pppoe-ia-rate-limit          Disabled
psecure-violation            Disabled
security-violation           Disabled
sfp-config-mismatch          Disabled
small-frame                  Disabled
storm-control                Enabled
udld                         Disabled
vmps                         Disabled
psp                          Disabled
Timer interval: 60 seconds
interface FastEthernet0/17
storm-control broadcast level 15.00
storm-control action shutdown
storm-control action trap
spanning-tree portfast
spanning-tree bpdufilter enable
Purple
storm control has got nothing to do with loops, it's just a feature that measures the amount of broadcast or unicast or multicast frames entering the port and when a threshold is attained it will either drop the traffic or errdisable the port which is your case.
when you reenable the port if the level of broadcast is below the threshold then the port will stay up.
Regards.
Alain
Hi Alain,
thanks for your reply. As you descripted with reenable the port .. but I did not reenabled the port manually.. they should check if  still Broadcast ,unicast  etc. reached the threshold if yes the interface should go down again at second time but during the second time check the port is up automaticly.
Ahmet
Purple
So that probably means the level of broadcast is then under the configured threshold, can you do sh storm-control broadcast as well as sh interface to verify.
Regards.
Alain
here the output
before
OB#sh storm-control broadcast
Interface  Filter State   Upper        Lower        Current
Fa0/15     Link Down         1.00%        1.00%        0.00%
Fa0/16     Link Down         1.00%        1.00%        0.00%
Fa0/17     Forwarding       15.00%       15.00%        0.00%
Fa0/18     Link Down         1.00%        1.00%        0.00%
Fa0/19     Link Down         1.00%        1.00%        0.00%
Fa0/20     Link Down         1.00%        1.00%        0.00%
OB#sh int fa0/17
FastEthernet0/17 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 0023.3437.3111 (bia 0023.3437.3111)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 17:47:48, output 00:00:06, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 260000 bits/sec, 374 packets/sec
     4281334 packets input, 685056789 bytes, 0 no buffer
     Received 4280209 broadcasts (3899080 multicasts)
     0 watchdog, 3899080 multicast, 0 pause input
     11862 packets output, 1276994 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
after
OB#sh int fa0/17
     reliability 255/255, txload 1/255, rxload 2/255
  Last input 17:52:50, output 00:00:21, output hang never
  5 minute input rate 878000 bits/sec, 793 packets/sec
     4643316 packets input, 738767326 bytes, 0 no buffer
     Received 4641947 broadcasts (4231292 multicasts)
     0 watchdog, 4231292 multicast, 0 pause input
     11992 packets output, 1291254 bytes, 0 underruns
Ahmet
Purple
storm-control was not in effect in both cases as the current broadcast level was under the threshold.
Regards.
Alain
Silver
For how long does your fa0/17 interface go up after re-enabled via the timer? As the traffic measurements and comparisons are based on 1 second time interval it should always go up for at least 1 second after re-enabled even if the loop remains there.
Best regards,
Antonin
the Fa0/17 goes up after the timer and was still up I don't see any logs.
Best Regards,
Ahmet
1239
