Webcast-Catalyst9k
Error : 5w2d: %SW_MATM-4-MACFLAP_NOTIF: flapping
Can someone help with VLAN flapping Issue, I have connected port gi0/2 of 2960 series switch to Cisco 4500 series having Gigabit Ethernet Module
and get error message
5w2d: %SW_MATM-4-MACFLAP_NOTIF: Host 000d.9d4c.cb5a in vlan 1 is flapping between port Gi0/2 and port Fa0/33
5w2d: %SW_MATM-4-MACFLAP_NOTIF: Host 001a.a00d.d9d3 in vlan 1 is flapping between port Gi0/2 and port Fa0/15
5w2d: %SW_MATM-4-MACFLAP_NOTIF: Host 000d.9d4c.cb5a in vlan 1 is flapping between port Fa0/33 and port Gi0/2
Port 4/10 of 4500 Series Switch is connected to port gi0/2 of 2960 series switch
config on 4500
interface gi 4/10
switchport mode trunk
config on 2960
interface gi 0/2
switchport mode trunk (( it doesnt takes the command "switchport trunk encapsulation dot1q" )
003269: *Aug 3 17:57:43: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to up
003270: *Aug 3 18:05:33: %ETHCNTR-3-LOOP_BACK_DETECTED: Keepalive packet loop-back detected on GigabitEthernet0/2.
003271: *Aug 3 18:05:33: %PM-4-ERR_DISABLE: loopback error detected on Gi0/2, putting Gi0/2 in err-disable state
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Error : 5w2d: %SW_MATM-4-MACFLAP_NOTIF: flapping
Hello Ronald,
if the C2960 is managed by other people there is not a lot to do.
for access layer switches that you manage you can use
spanning-tree bpdu guard on all access ports (not on uplinks)
There are commands to configure timers for autorecovery from errordisable
errdisable recovery cause ?
all Enable timer to recover from all causes
arp-inspection Enable timer to recover from arp inspection error disable state
bpduguard Enable timer to recover from BPDU Guard error disable state
channel-misconfig Enable timer to recover from channel misconfig disable state
dhcp-rate-limit Enable timer to recover from dhcp-rate-limit error disable state
dtp-flap Enable timer to recover from dtp-flap error disable state
gbic-invalid Enable timer to recover from invalid GBIC error disable state
inline-power Enable timer to recover from inline-power error disable state
l2ptguard Enable timer to recover from l2protocol-tunnel error disable state
link-flap Enable timer to recover from link-flap error disable state
loopback Enable timer to recover from loopback disable state
pagp-flap Enable timer to recover from pagp-flap error disable state
psecure-violation Enable timer to recover from psecure violation disable state
security-violation Enable timer to recover from 802.1x violation disable state
sfp-config-mismatch Enable timer to recover from SFP config mismatch error disable state
storm-control Enable timer to recover from storm-control error disable state
udld Enable timer to recover from udld error disable state
unicast-flood Enable timer to recover from unicast flood disable state
vmps Enable timer to recover from vmps shutdown error disable state
you can specify cause and the time interval
(I took this from a C3560 but it should be present also on the C4500 the list of possible causes can be different)
Hope to help
Giuseppe
Hello Ronald,
the C2960 doesn't accept the command switchport trunk encapsulation dot1q if it supports only 802.1Q as it happens on C2950.
About the second issue:
There is a SW bug that affects some IOS version of C2950, C2960, and C3750 where the switch treats the reception of its own loopback frames as a sign of a problem insteaf of a good sign.
the workaround is to disable on affected fiber based GE ports
the Cisco bug-id has been provided in a thread of last march.
with
int gi0/2
no keepalive
or an IOS upgrade
see
The bug affects some IOS releases on some switch platforms on fiber based ports.
see this thread
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cc1ebcc/5#selected_message
you may need to copy to browser the text to be able to open the link
you can find this using search box on the top right with key LOOP_BACK_DETECTED
Hope to help
Giuseppe
Thanks.
Some switches are controlled by other departments is there a way to restrict on the 4500 to block cascading of switches.
I dont want the 2960 to be cascaded with another Switch.
I dont want other department to connect hub or switch to any ports of 2960
Switch goes to error-disable state, is there a way to remove from error-disable state automatically ( Mean with timeout options )
Hello Ronald,
Hope to help
Giuseppe
Thanks Giuseppe.
I have few more query.
(1) Can I use command "errdisable recovery" on uplinks or access ports or both.
(2) Gi0/1 of 2960 is connected to 4500, gi0/2 of 2960 is connected to another 2960 switch(2). Is command "switchport mode trunk" enough for 2960_switch(2)
(3) I have a scenario where I need to connect 2960 to another 2960 switch, for redundancy I need to connect two ports of each switch to other switch, what commands are required. Is there an option to combine these ports as one.
1)it's a global configuration command and affects for all errdisabled ports
2)yes, it's doing only dot1Q, ISL is not supported.
3)you've to bundle them in an etherchannel:
int fas0/1
channel-group 1 mode desirable/active/auto/passive/on
int fas0/2
interface port-channel 1
the port-channel acts as a logical interface for the 2 physical interfaces.
Note that ports you want to bundle need same characteristics (speed,...)
IKf you don't use a port-channel but two separate trunk links. The link with the highest portnumber will be blocked by STP. In other words, only 1 link will be used
Thanks.
I have connected PC to console port on 4500 but not able to see ports going up and down. I have enabled logging console.
what is missing???
(2) Is there any other way to check if the ports are down due to error disable apart from sh logging console.
(3)WHY channel-group 1 mode desirable is more used than other option ( on / active / auto )
1) logging event link-status (global config)
global linkstatus logging is disabled in the IOS you're using for this platform
for 3750, 3560, 2960, ... linkstatus logging is enabled by default
2) show interface status errdisable
3)maybe because desirable/auto (PaGP) is cisco propietary
HTH,
please rate posts if usefull
3470
