Error changing boot image on Nexus 3548 series -Note: system and kickstart bootvars are pointing to incompatible images
CiscoPurpleBelt
Level 6
Level 6
So I have a pair of 93000 Nexus switches.
One switch is pointed to and using the following fine:
kickstart variable = bootflash:/n3500-uk9-kickstart.6.0.2.A8.9.bin
system variable = bootflash:/n3500-uk9.6.0.2.A8.8.bin
I change and point to the same software and receive the following:
switch 1(config)# boot system bootflash:n3500-uk9.6.0.2.A8.8.bin
Performing image verification and compatibility check,please wait....
switch 1 (config)# boot system bootflash:n3500-uk9-kickstart.6.0.2.A8.9.bin
Failed to configure bootvar system for sup-1: mismatch between actual image type and boot variable (0x4045001E)
Any idea what is wrong guys?
Thanks yes I referred to this. SO why I a check I get:
Switch 1# sh install all impact system bootflash:n3500-uk9-kickstart.6.0.2.A8.9.bin
Installer is forced disruptive
Verifying image bootflash:/n3500-uk9-kickstart.6.0.2.A7.2.bin for boot variable "kickstart".
[########################################] 100% -- SUCCESS
Verifying image bootflash:/n3500-uk9-kickstart.6.0.2.A8.9.bin for boot variable "system".
[#                                       ]   2% -- FAIL. Return code 0x4045001E (mismatch betw
een actual image type and boot variable).
Pre-upgrade check failed. Return code 0x40930011 (Image verification failed).
I don't know why since there are no problems with the other switch.
Your post says 9300 but the image you are trying to load is for the 3000 series (n3500-uk9-kickstart.6.0.2.A7.2.bin).
Which is correct?
Sorry I have too many issue right now (see other posts if interested :)
Good catch - correction the switches are 3548 series.
