Community Member
Error connecting to a router 10/100 8-Port VPN Router RV082 to a Forefront Gatteway 2010
I'm new in terms of the Cisco router. I'm having problems connecting to an RV082 router to a TMG (Forefront Gatteway 2010).
The connection should be as follows, the RV082 router for TMG. In plainer terms RV082 (Company / Headquarters) -> Internet -> TMG 2010 (Subsidiary Company)- internal network
Clicking VPN gives the following errors and checking the logs of VPN exist the following errors
Apr 13 20:40:29 2012 VPN Log [Tunnel Negotiation Info] >>> Initiator Send Main Mode 1st packet
Apr 13 20:40:29 2012 VPN Log Initiating Main Mode
The following settings are on the RV082 router
Tunnel NO: 1
Name tunnel?: Remoto_teste
WAN1 Interface
Enable: Yes
Local Security: IP Only
IP Address: 192.168.1.6
Local Security Group type: Ip Range -> 10.1.1.1
Remote Setup group
remote security gateway: IP only
Ip Address: 189.2 ... .. ..
Security remote group: ip range
IPSEC Setup
Keying mode: IKE with Preshared key
Phase1 DH Group: Group2
Phase2 DH-256 AES Encryption
Phase1 Authentication SHA1
Phase1 SA Life Time 28800 seconds
Forwad Perfect Secrecy: Yes
Phase2 DH Group: Group2
Phase2 Encrypton AES-256
Phase2 Authentication SHA1
Phase2 SA Life Time 28800 seconds
Preshared Key: ABCD12345
Settings TMG
PPTP Enabled
Method of Microsoft encrypted authentication version 2 (MS_ chap_v2): Enabled
Allow IPsec policy for L2TP connection personilizada
IPSEC Settings
Encryption algorithm: AES206
Integrity algorithm: SHA1
Diffie-Hellman group: Group 2 (1024 bits)
Authenticate and generate key 28800
Authentication Key: ABCD12345
What I may be wrong for this connection is not closing '.
Thank you all.
350
