error-disable on the switch port
Hi All,
Does anyone know what does this mean?
FastEthernet0/11 is down, line protocol is down (err-disabled)
ovt Bronze
Bronze
Re: error-disable on the switch port
The system has many reasons to errdisable a port ;) Read command ref. about "errdisable detect cause" command.
Gold
Causes od Error disable
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00806cd87b.shtml#topic3
You can turn off error disable feature with command
no errdisable detect cause all
You can also turn on error disable recovery with command
errdisable recovery cause all
M.
Hope that helps rate if it does
you can also do a shut and no shut to the interface to recover from error disabled condition
Narayan
This is a general error condition when a port has been disabled by the Catalyst Switch.
Maybe this is a STP or ARP Security issue.
You could use something like this to enable the reporting of more specific cause that disable the port
(config)#errdisable detect cause
Gabriele
380
