09-25-2011 09:26 PM - edited 03-07-2019 02:25 AM
We have got error-disabled on the Up Link of switch cisco 2960 at customer site but as per config this port is somply trunk port.
Error logs for this issue is below,
Log Buffer (4096 bytes):
_DISABLE: loopback error detected on Gi0/1, putting Gi0/1 in err-disable state
Also attaching show tech-support and show logging for this switch,
Ashutosh
09-25-2011 09:35 PM
Are you sure this is the correct switch?
09-26-2011 03:07 AM
Yes,
These are logs of the switch faced issue.
Ashutosh
09-26-2011 04:49 AM
I've never personally seen this issue up close and personal, but I have read about it a few times. This appears to
be when an ethernet keepalive is being sent out of an interface and is also received on the same interface it
sent it out on. It sounds like a logical Spanning Tree loop. When I read about this a few months ago, most of the
fixes were to upgrade the IOS to a certain version and or disable ethernet keepalives on the specified port.
09-26-2011 03:48 PM
Can you please post the "sh tech" of the other switch then?
09-27-2011 04:56 AM
Find attached here show tech-support of the switch connected through this UP Link port G0/1 of reported switch.
Ashutosh
