Error in 3524XL
I am getting the following error in cisco switch 3524XL:
Feb 1 01:21:00: %LINK-4-ERROR: FastEthernet0/20 is experiencing errors
Please suggest the wright answer to fix the problem
Re: Error in 3524XL
Both sides duplex is 100 full and I cleared the counters also, but still errors are coming in logs....please help me regarding this issue.....
Re: Error in 3524XL
hi,
can you post the sh interface output?
which kind of errors are you getting?
regards,
shri :)
Re: Error in 3524XL
#sh int f0/13
FastEthernet0/13 is up, line protocol is up
Hardware is Fast Ethernet, address is 00d0.bbd2.260d (bia
00d0.bbd2.260d)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive not set
Auto-duplex (Full), Auto Speed (100), 100BaseTX/FX
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters 12:58:47
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute output rate 6000 bits/sec, 5 packets/sec
218510 packets input, 78936683 bytes
Received 1073 broadcasts, 0 runts, 0 giants, 0 throttles
147 input errors, 147 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 538 multicast
467270 packets output, 258862433 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier
I did a clear count f0/13 last night. Input and CRC errors were rising
at a moderate rate.
Re: Error in 3524XL
When i am seeing the logs, the below error is showing....
Feb 1 01:21:00: %LINK-4-ERROR: FastEthernet0/13e is experiencing errors
Re: Error in 3524XL
hi,
AFAIK the input errors you are receiving is the sum of runts, CRC errors and that kind of errors.In your case these are only CRC errors are present.
Cyclic redundancy checksum generated by the originating LAN station or far-end device does not match the checksum calculated from the data received. On a LAN, this usually indicates noise or transmission problems on the LAN interface or the LAN bus itself. A high number of CRCs is usually the result of collisions or a station transmitting bad data.Can you check the duplex setting @ other end?
regards,
shri :)
Re: Error in 3524XL
This is whats causing the issue and there are 2 things you need to do.
1. Make sure both the speed and Duplex setting on both ends are the same. Either hardcoded or set to auto (negotiating to the same values)
You can check the speed and duplex setting by looking under sh interface int fa 0/20
2.Change the cable.
Re: Error in 3524XL
Thank u...i done what u have given sugestion...but anyhow I will recheck the same...
Krishna
Re: Error in 3524XL
Just wanted to clarify,
1>either have both sides hardcoded
2>Have both sides set to auto.
thanks
Re: Error in 3524XL
Could you have the same problem that I have.
Interface going up and down on pc?
CSCec00968 Bug Details
Cat3524 incompatibility w/Intel Pro/1000 MT NICs
The 3500XL may be incompatible with some other vendors' NIC's.
A Catalyst 3524-PWR XL switch does not work correctly with some Intel Pro/1000 MT network interface cards (NICs).
This is an Intel product defect. There is no workaround. (CSCec00968)
315
