04-24-2010 02:01 PM - edited 03-06-2019 10:47 AM
hi all,
i did write erase and then did delete flash:vlan.dat after that i reloaded
when switch was booting up i get error
Error loading "flash:/c2950-i6k2l2q4-mz.121-22.EA8a.bin"
after this message switch booted ok
here is sh flash and other info
Switch#verify ?
/ios Verify compressed IOS image checksum
/md5 Compute an md5 signature for a file
flash: File to be verified
Switch#verify flash:/c2950-i6k2l2q4-mz.121-22.EA8a.bin
%Error verifying flash:/c2950-i6k2l2q4-mz.121-22.EA8a.bin (No such file or direc
tory)
Switch#sh flash:
Directory of flash:/
2 -rwx 3721946 Mar 01 1993 00:31:57 +00:00 c2950-i6k2l2q4-mz.121-22.E
A13.bin
7 -rwx 316 Oct 28 1993 05:57:54 +00:00 env_vars
21 -rwx 109 Mar 01 1993 00:04:19 +00:00 info
22 -rwx 109 Mar 01 1993 00:04:19 +00:00 info.ver
7741440 bytes total (4016640 bytes free)
my question is is everything ok with my switch?????????
many thanks
mahesh
Solved! Go to Solution.
04-24-2010 02:06 PM
mahesh18 wrote:
hi all,
Switch#sh flash:
A13.bin
22 -rwx 109 Mar 01 1993 00:04:19 +00:00 info.ver7741440 bytes total (4016640 bytes free)
many thanks
mahesh
Mahesh
Your switch is trying to boot an image that isn't there. Perhaps you had a boot system ... statement in your running-config that pointed to EA13 image but when you deleted the running-config it fell back to the bootvar ?
Your switch is fine but i would suggest -
1) do a "sh version" and make sure the switch is using the EA13 image
2) add this to your config -
switch(config)# boot system flash flash:/c2950-i6k2l2q4-mz.121-22.EA13.bin
save the config and reload the switch and see if you still get the same error message.
Jon
04-24-2010 02:06 PM
mahesh18 wrote:
hi all,
Switch#sh flash:
A13.bin
many thanks
mahesh
Mahesh
Jon
04-24-2010 02:19 PM
Hi jon
I did exactly as you said and error is gone now.
Many thanks
best regards
mahesh
