Error Logs in 6509
%SYSTEM_CONTROLLER-SP-3-ERROR: Error condition detected: TM_DATA_PARITY_ERROR
Feb 2 10:57:09.602 EST: %SYSTEM_CONTROLLER-SP-3-EXCESSIVE_RESET: System Controller is getting reset so frequently
IOS (tm) s222_rp Software (s222_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF15a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 20-Oct-08 19:20 by kellythw
Image text-base: 0x40101040, data-base: 0x42951080
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTLDR: s222_rp Software (s222_rp-IPSERVICES_WAN-M), Version 12.2(18)SXF15a, RELEASE SOFTWARE (fc1)
HKDDCAR24 uptime is 2 years, 47 weeks, 4 days, 23 hours, 40 minutes
Time since HKDDCAR24 switched to active is 2 years, 47 weeks, 4 days, 23 hours, 38 minutes
System returned to ROM by  power cycle (SP by reload)
System restarted at 20:15:39 EST Fri Mar 6 2009
System image file is "disk0:s222-ipservices_wan-mz.122-18.SXF15a.bin"
cisco WS-C6509 (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory.
Processor board ID SCA053701RJ
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
13 Virtual Ethernet/IEEE 802.3 interfaces
100 Gigabit Ethernet/IEEE 802.3 interfaces
381K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
1 REPLY
Error Logs in 6509
Hi Chandra,
Parity error if seen once is usually transient. In this case it seems to be fixed by itself without reload needed. You can monitor it for a while and if not reoccured leave it without worrying. On reoccurrence I would recomend to consider SUP replacement.
To learn more about Parity Errors please check the following CCO documentations:
https://www.cisco.com/en/US/products/hw/routers/ps341/products_tech_note09186a0080094793.shtml
http://www.cisco.com/en/US/products/hw/routers/ps167/products_tech_note09186a0080094340.shtml
Hope this helps,
Nik
900
