Error message on ASR 1000 logs.
Hi Everyone,
Good day.
I am seeing the below errors from the ASR 1000 that I have and It is not very clear on what the error actually means.
If someone have had experience with this kind of similar error message, kindly assist:
Apr 11 12:02:08.744 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:09.442 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:13.381 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:13.986 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:18.312 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:18.765 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:22.827 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:23.449 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:27.777 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:28.090 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:32.649 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:32.686 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:37.397 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:37.552 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:42.062 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:42.259 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:46.775 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:47.200 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:51.347 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:51.977 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:56.271 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:02:56.835 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:03:01.140 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:03:01.787 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:03:06.064 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:03:06.325 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:03:10.949 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:03:11.039 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:03:15.533 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Apr 11 12:03:15.858 AEST: ASR1000-INJECT: can't find tunnel adj for 0.0.0.0
Kanes.R
  • LAN Switching and Routing
VIP Super Bronze
Hi,Are running any IPSEC/VPN
Are running any IPSEC/VPN tunnel on this device?
Hi Rez, Yes DMVPN.
Hi Rez,
Yes DMVPN.
VIP Super Bronze
Hi,Ok, the message is
Ok, the message is indicating that one of the tunnels can't find the adj device through default route (0.0.0.0)
Check your tunnels and make sure they are all working correctly and have peering. I am not sure if this is possible, but see if you can figure out if the tunnels have been running for some times or anyone of them flapping
Hi Reza, Thanks for the
Hi Reza,
Thanks for the update. However is there a specific way I can determine what is trying to establish a connection to the router and what is not? Based on the show DMVPN and so on I can see that the all of the tunnel has been up for over 5 weeks.
Thanks in advance.
Kanes.R
111
