Community Member
error on catalyst 2950
C2950 Boot Loader (C2950-HBOOT-M) Version 12.1(11r)EA1, RELEASE SOFTWARE (fc1)
Compiled Mon 22-Jul-02 17:18 by antonino
WS-C2950-24 starting...
Base ethernet MAC Address: 00:17:5a:1c:77:40
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 373 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4752384
flashfs[0]: Bytes available: 2989056
flashfs[0]: flashfs fsck took 7 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading "flash:/c2950-i6q4l2-mz.121-22.EA6.bin"...#############################################################################################################################################################################################################
File "flash:/c2950-i6q4l2-mz.121-22.EA6.bin" uncompressed and installed, entry point: 0x80010000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 21-Oct-05 01:59 by yenanh
Image text-base: 0x80010000, data-base: 0x80568000
Initializing flashfs...
flashfs[1]: 373 files, 4 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 4752384
flashfs[1]: Bytes available: 2989056
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
Done initializing flashfs.
POST: System Board Test : Passed
POST: Ethernet Controller Test : Passed
ASIC Initialization Passed
%Error: initializing transceiver port Fa0/1
%Error: initializing transceiver port Fa0/2
%Error: initializing transceiver port Fa0/3
%Error: initializing transceiver port Fa0/4
%Error: initializing transceiver port Fa0/5
%Error: initializing transceiver port Fa0/6
%Error: initializing transceiver port Fa0/7
%Error: initializing transceiver port Fa0/8
%Error: initializing transceiver port Fa0/9
%Error: initializing transceiver port Fa0/10
%Error: initializing transceiver port Fa0/11
%Error: initializing transceiver port Fa0/12
%Error: initializing transceiver port Fa0/13
%Error: initializing transceiver port Fa0/14
%Error: initializing transceiver port Fa0/15
%Error: initializing transceiver port Fa0/16
%Error: initializing transceiver port Fa0/17
%Error: initializing transceiver port Fa0/18
%Error: initializing transceiver port Fa0/19
%Error: initializing transceiver port Fa0/20
%Error: initializing transceiver port Fa0/21
%Error: initializing transceiver port Fa0/22
%Error: initializing transceiver port Fa0/23
%Error: initializing transceiver port Fa0/24
how do i solve this big issue,is the switch bad or can be solved
Purple
Re: error on catalyst 2950
It's a hardware error and its failing post , time to RMA the box if you have a contract. If you have tried rebooting numerous times then get it replaced.
Hall of Fame Super Gold
I'm with Glen. The 2950 can now be used as a door jam until you contact Cisco and get the appliance replaced.
Are you getting any error messages AFTER the %Error: initializing?
Is there something such as:
POST set PHY loopback failed.strata_cmic_read_miim ERROR:
timeout (addr=0x00 id=0x0D)
If you let the switch on longer, does it have any other error messages or it reboots right after the initializing?
Community Member
i have the above messages displayed,but didnt really notice it rebooting.i awiat ur quick response on next step.thanks
Community Member
Hi Lavramov,
Please am waiting for update on this issue.i said the switch displays message u sent.
1226
