Webcast-Catalyst9k
%Error opening nvram:/startup-config (Invalid Checksum)
Silver
Re: %Error opening nvram:/startup-config (Invalid Checksum)
Hi ,
These error messages usually indicate a hardware failure. To verify, issue the test memory command. This is an example of the command output:
Router#test memory
Test NVRAM card [y/n] ? y
Failed
Issue the write erase command and reload the router. If the issue persists, the hardware will need to be replaced.
Satish
Blue
652
