10-04-2014 05:09 AM - edited 03-07-2019 08:59 PM
Hi Gurus,
I have ben continuously receiving this error since days. Looks like the Router is trying to boot from the network. Here the router is standalone and is in no network. Consider it as new.
%Error opening tftp://255.255.255.255/Router8-auto (Timed out)
%Error opening tftp://255.255.255.255/Network-auto (Timed out)
when trying to load an image..
Router1_2691#copy running-config startup-config
Destination filename [startup-config]?
Building configuration...
Compressed configuration from 1976 bytes to 1145 bytes[OK]
Router1_2691#copy startup-config tftp
Address or name of remote host []? 192.168.0.12
Destination filename [Router8-auto]? Router1
Uncompressed configuration from 1145 bytes to 1976 bytes.....
%Error opening tftp://192.168.0.12/Router1 (Timed out)
Router1_2691#
Router1_2691(config)#no logg
Router1_2691(config)#no logging con
Router1_2691(config)#no logging console
Router1_2691(config)#exit
Tried all the above from previous blogs.. no luck ;(
please advise how I can load an IOS image to this router.I am using the tool tftpd.
error in tftpd is as below
Message truncated (length was 8) [04/10 12:53:53.419]
Also attached is the output of 'show config'
10-04-2014 07:54 AM
few more messages popping up. I know the reason why these are popping up.. but do not know how to get rid of them...
Still learning..
%Error opening tftp://255.255.255.255/Router8-auto (Timed out)255.255/Network-auto (Timed out)
