Error - Standby console disabled on new Sup 6E for 4500
I got 2 fiber connected to two core from this 4500 with two SUP. I am trying to console to standby sup and it says standby console disabled.
Thanks in advance
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: Error - Standby console disabled on new Sup 6E for 4500
You Sups are in a redundant mode.  In redundant mode you only have access to the primary unless the primary fails.
You should configure everything from the primary and no need to worry about the stand-by Sup.  The config changes will be synced from the primary to stand-by Sup.
Reza
VIP Super Bronze
Are you running the Sups in redundant (SSO) mode?
Reza
RPR
SACHIN PAUL
RPR
Thanks for your reply. I see the below error when i try to console.
Switch-standby>en
Standby console disabled.
Valid commands are: exit, logout
Do i need to enable the standby console from config-r mc? Why the new SUPs are not default console enabled?
VIP Super Bronze
Reza
That makes sense. But how i am going to configure one of the uplink port on my standby SUP?
VIP Super Bronze
From the primary.
I will test quick. Thanks.
1112
