errors across port-channel
Guys,
We've got a 4gig port-channel running from a 4506 -> 3750 (2 switch) stack.
We received a call last week regarding the network going slow and on the off chance we seen this issue and thought that the errors may have just been historical. The counters have been cleared 4 days ago but now they are nearly 1 million errors on the port-channel. It's strange as all 4 ports are configured with the same settings. I will post the outputs to the bottom of this and see if any of you experts can shed some light into this matter.
Thanks for your time!
Thomas.
4506 -
4506# sh int po5
Port-channel5 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 000f.2386.f700 (bia 000f.2386.f700)
  Description: Link (4Gb/s) to 3750
  MTU 1500 bytes, BW 4000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 6/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is N/A
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Gi5/33 Gi5/34 Gi5/35 Gi5/36
  Last input 1w4d, output never, output hang never
  Last clearing of "show interface" counters 4d05h
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 94389000 bits/sec, 8567 packets/sec
  5 minute output rate 3832000 bits/sec, 2974 packets/sec
     1403144761 packets input, 2006168020857 bytes, 0 no buffer
     Received 819344 broadcasts (249140 multicast)
     911095 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     663932228 packets output, 82535420512 bytes, 0 underruns
     0 lost carrier, 0 no carrier
interface Port-channel5
description Link (4Gb/s) to 3750
switchport
switchport trunk allowed vlan 1,6-11,21
switchport mode trunk
end
interface GigabitEthernet5/33
description Link to 3750 Gi1/0/1
speed 1000
duplex full
qos trust dscp
channel-group 5 mode active
end
interface GigabitEthernet5/34
description Link to gh5-d3750-1 Gi2/0/2
speed 1000
duplex full
qos trust dscp
end
interface GigabitEthernet5/35
description Link to 3750 Gi1/0/3
speed 1000
duplex full
qos trust dscp
end
interface GigabitEthernet5/36
description Link to 3750 Gi2/0/4
speed 1000
duplex full
qos trust dscp
end
3750
3750# sh int po1
Port-channel1 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0022.be4d.f783 (bia 0022.be4d.f783)
  Description: Link (4Gb/s) to 4506
     reliability 255/255, txload 5/255, rxload 1/255
  Full-duplex, 1000Mb/s, link type is auto, media type is unknown
  Members in this channel: Gi1/0/1 Gi1/0/3 Gi2/0/2 Gi2/0/4
  Last input 00:00:00, output 00:00:27, output hang never
  5 minute input rate 3639000 bits/sec, 2795 packets/sec
  5 minute output rate 87688000 bits/sec, 7976 packets/sec
     67438141775 packets input, 8960156703405 bytes, 0 no buffer
     Received 811103312 broadcasts (0 multicasts)
     0 watchdog, 510144132 multicast, 0 pause input
     146300873944 packets output, 210615114944396 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
description Link to 4506 Gi5/33
speed 1000
duplex full
no mdix auto
channel-group 1 mode active
spanning-tree guard root
end
interface GigabitEthernet1/0/3
description Link to 4506 Gi5/35
speed 1000
duplex full
no mdix auto
interface GigabitEthernet2/0/2
description Link to 4506 Gi5/34
speed 1000
duplex full
no mdix auto
end
interface GigabitEthernet2/0/4
description Link to 4506 Gi5/36
speed 1000
duplex full
no mdix auto
end
Everyone's tags (2)
Re: errors across port-channel
Could you please check the output of "show controller ethernet-controller " and see if there are any errors in there? A typical output would look like below:
sh controllers ethernet-controller fa 0/1
     Transmit FastEthernet0/1                 Receive
      6213609 Bytes                          4660517 Bytes
        11954 Unicast frames                   12102 Unicast frames
        70472 Multicast frames                 40914 Multicast frames
          514 Broadcast frames                  1608 Broadcast frames
            0 Too old frames                  776328 Unicast bytes
            0 Deferred frames                3578396 Multicast bytes
            0 MTU exceeded frames             160275 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames               13682 Minimum size frames
            0 8 collision frames               37725 65 to 127 byte frames
            0 9 collision frames                1112 128 to 255 byte frames
            0 10 collision frames               2105 256 to 511 byte frames
            0 11 collision frames                  0 512 to 1023 byte frames
            0 12 collision frames                  0 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames                  0 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
        69811 64 byte frames                       0 Valid frames, too small
        10210 127 byte frames
          595 255 byte frames                      0 Too old frames
         2226 511 byte frames                      0 Valid oversize frames
           96 1023 byte frames                     0 System FCS error frames
            2 1518 byte frames                     0 RxPortFifoFull drop frame
            0 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
Hope this helps.
NT
Unfortunately our 4500 doesn't seem to have that command but is still racking up on the errors. I am just thinking how actual critical these errors actually are? Since we've had that many already on the interface and nothing has been done.
I know that's not the correct attitude but it's strange how it's sporadic over the 4 physical interfaces with no prejudice on 1 gig port than any other.
If anyone can help that would be a massive help as I think am hitting my head off a brick wall.
Cheers,
Thomas.
942
