06-15-2008 12:46 AM - edited 03-05-2019 11:38 PM
I am getting errors on my core router interface. Please check the following show interfaces output.
JED-7iHO-GWR-01#show interfaces gigabitEthernet 6/1
GigabitEthernet6/1 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0018.742e.46c0 (bia 0018.742e.46c0)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is LH
input flow-control is off, output flow-control is off
Clock mode is auto
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d01h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2941000 bits/sec, 813 packets/sec
5 minute output rate 4506000 bits/sec, 882 packets/sec
L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
79154295 packets input, 46040134808 bytes, 0 no buffer
Received 50211 broadcasts (0 IP multicasts)
11054 runts, 0 giants, 0 throttles
168540 input errors, 11054 CRC, 157340 frame, 259 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
82923681 packets output, 47321843099 bytes, 0 underruns
0 lost carrier, 0 no carrier, 0 pause output
Please let me know what could be the reson for this and how to start trouble shooting for this issue.
06-15-2008 12:55 AM
Saleemuddin,
Would you please post "show interface
Thot
06-15-2008 01:33 AM
Saleemuddin,
Seems you are using GBIC on this port.
"Full-duplex, 1000Mb/s, media type is LH"
Do these errors still increase?
Can you do "clear counter
Thot
06-15-2008 02:01 AM
interface GigabitEthernet6/1
no ip address
ip flow ingress
interface GigabitEthernet6/1.464
description 1Giga Link To STC
encapsulation dot1Q 464
ip address 172.31.23.158 255.255.255.252
interface GigabitEthernet6/1.469
description Interface For DSL SERVICES
encapsulation dot1Q 469
ip address 10.30.50.10 255.255.255.252
interface GigabitEthernet6/1.473
description Interface For Seven-I National Link
encapsulation dot1Q 473
ip address 212.118.152.222 255.255.255.252
no ip redirects
ip flow ingress
interface GigabitEthernet6/1.1470
ip flow ingress
no cdp enable
interface GigabitEthernet6/1.2698
description New Interface to IGW
encapsulation dot1Q 2698
ip address 84.235.110.90 255.255.255.252
ip access-group IDS_GigabitEthernet6/1.2698_in_0 in
