ERSPAN Between Two Routers
ty.chan007
I am trying to mirror traffic from one router to another with below config:
R1:
R1#sh run | sec monitor
monitor session 1 type erspan-source
source interface Gi0/0/3 rx
destination
  erspan-id 100
  ip address 192.168.0.0
  origin ip address 192.168.0.1
R11#sh monitor session all
Session 1
Type                   : ERSPAN Source Session
Status                 : Admin Enabled
Source Ports           :
    RX Only            : Gi0/0/3
Destination IP Address : 192.168.0.0
Destination ERSPAN ID  : 100
Origin IP Address      : 192.168.0.1
R2:
R2#sh run | sec monitor
monitor session 1 type erspan-destination
destination interface Gi0/0/4
source
  erspan-id 100
R2#sh monitor session all
Session 1
Type                   : ERSPAN Destination Session
Destination Ports      : Gi0/0/4
Source IP Address      : 192.168.0.1
Source ERSPAN ID       : 100
R2#sh platform hardware qfp active feature erspan state
ERSPAN State:
  Status    : Active
  Complexes : 1
  CPPs      : 1
Capabilites:
  Max sessions : 1024
  Max outputs  : 128
  Encaps type  : ERSPAN type-II
  GRE protocol : 0x88BE
  MTU          : 1464
  IP TOS       : 0
  IP TTL       : 255
  COS          : 0
System Statistics:
  DROP src session replica  :                  0 /                  0
  DROP term session replica :                  0 /                  0
  DROP receive malformed    :                  0 /                  0
DROP receive invalid ID   :           24321174 /        21427043334
  DROP recycle queue full   :                  0 /                  0
  DROP no GPM memory        :                  0 /                  0
  DROP no channel memory    :                  0 /                  0
Client Debug Config:
  Enabled: Info, Warn
Data Path Debug Config:
  0x00000000
Note:  192.168.0.0 is R2's loopback. 192.168.0.1 is R1's loopback.
The configuration seems OK and traffic was mirror from R1 to R2 but it was dropped at R2 with DROP receive invalid ID increasing.
What could go wrong? please help.
I see you again reverted to original config. As I told above that is wrong - ip address in destination session and ip address in source session should match. If they dont- that is causing the drops you see.
So I recoemnd following:
- remove both sessions completely
- configure both with new session id - e.g. 101
- configure "ip address" in source and destination sessions to be 192.168.0.0
- have "plim ethernet vlan filter disable"command on outgoing interface
Nik
HTH,
Niko
9 Replies 9
nkarpysh
The ERSPAN-Destination session should have the Source IP Address as the
IP address (192.168.0.0) and not the Origin IP Address which you have
configured.
Try changing that and let me know if that helped.
Nik
+pls grade if helpful
HTH,
Niko
Do you mean i need to change on R2 as below:
source
  erspan-id 100
To:
source
  erspan-id 100
I did that but ERSPAN stop working.
Can you paste the current output for
show platform hard qfp active feature erspan state
Previously "DROP receive invalid ID" indicated exactly that erspan-id (or ips) in source and destination session didnot match.
And that is due to ip was incorrect-  I guess that is bug of documentation explaining that. Current config is correct.
From what I have seen there two things to try:
1. Remove ERSPAN completely from source and destination and apply again with defferent session id
if that did not help try option 2:
2. Configure "plim ethernet vlan filter disable" on destination router destination interface Gi0/0/4 as sometime problem is related to VLAN tags coming in ethernet header of captured frames.
Nik
HTH,
Niko
I have remove and add again with same and different session ID but not success. Below is the update result:
ASBR02-ANA#sh platform hardware qfp active feature erspan state
ERSPAN State:
  Status    : Active
  Complexes : 1
  CPPs      : 1
Capabilites:
  Max sessions : 1024
  Max outputs  : 128
  MTU          : 1464
  IP TOS       : 0
  IP TTL       : 255
  COS          : 0
System Statistics:
  DROP receive invalid ID   :          471497498 /       443368261666
  Enabled: Info, Warn
  0x00000000
The number keep increasing. Did try your command on the G0/0/4 but still not help.
Can you please share the current config.
Nik
HTH,
Niko
R1:
destination
  erspan-id 100
R2:
source
  erspan-id 100
Nik
HTH,
Niko
Hi Nik, It works now following exactly as you told. but don't really understand why it config that way.
Many Thanks
Glad it works.
Thing is that documentation seems to be not correct. "ip address" in source and destination should match and in guides I often see destination ip address matching to originator id which is wrong and we corrected it.
As for "plim ethernet vlan filter disable" - it is used to disable filter for packets tagged with VLAN as by default ASR drop them in older versions. I guess in later codes they overcome it.
Nik
HTH,
Niko
