ESW540 - disable port security
Brian Bergin
Level 4
Level 4
We have an ESW540 at a customer site that I need to know the best way to disable totally all port security.  The default config blocks more than 3 computers from passing which breaks things like WAPs but also servers with dozens of IPs.  They're running firmware 2.1.19 and just need this switch to act like it's basically a run-of-the-mill switch without it blocking connections to/from it.  Thanks...
jyoung
you have to set all the ports to type access point instead of host in the web interface.
I have the same problem but need to have VLAN 3 and VLAN 4 tagged on AP points.  If I set to host it only allows 1 VLAN.
Hi guys, you need to specify the smart port roles.
-Tom
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
