Community Member
ether channel not coming up on VSS(6509)
We are trying to configure VSS with two 6509 switches. The accsess(4507) is connteced to the vss(6509) distribution using MEC.
The port channel in the vss is not coming up. Following are the configurations on both switches.
in 6509 VSS
int port-channel 100
switchport
switchport trunk encap dot1q
switchport mode trunk
switchport nonegotiate
int te1/1/1
switchport
channel-protocol pagp
channel-group 100 mode desirable
int te2/1/1
switchport
switchport encap dot1q
in 4507 access
int port-channel 2
switchport
int ten3/1
switchport
channel-prot pagp
int tn4/1
switchport
channel-prot pagp
can any one please suggest why my port channel is not coming up on VSS switch with the above config.
Re: ether channel not coming up on VSS(6509)
Can u specify the channel protocol under the port-channel interface and check.
Mahmood
Community Member
We can not applly that command in port-channel interface.
Purple
Can you explain why on the 6500 you have int port channel 100 on the 6500 and you have int port channel 2 on the 4500 , assume that is a misprint on the 4500 side ? The channel-group under the interface looks ok though. Can you post a show etherchannel summary" for both sides? Usually in a negotiated etherchannel it will tell you in the logs why the etherchannel was not created .
At 4507 , the trunk ports uses ISL encapsulation instead of dot1q.
The Port's config has to be identical in order for ur Etherchannel to come up.
issue the following in both switches to examine the encapsulation type:
sh interfaces x/y switchport
Mohamed
Community Member
The issue here appears to be that you have configured 802.1Q tagging at one end of the links, but not the other.
On the C4507 configure the EtherChannel to use 802.1Q and the EtherChannel should come up.
Cisco do numerous checks to prevent the mis-configuration of EtherChannels, which if un-checked can cause major problems in your network.
The fact your EtherChannel didn't come up is actually a good thing, different encapsulations on each end would otherwise have caused a black hole scenario.
471
