Ether-Channel on 3750G-16TD-S & 3750x-48T-S with 10GB
Anyone have any experience with bundling a 10GB interface on a 3750G-16TD-S with a WS-C3750X-48T-S with a 10GB interface. I have worked with 5 different TAC engineers and so far I have not gotten an answer on why the switch will not let me bundle the 10GB with another 10GB interface.
Same switch Stack – not a cross stack.
Tried every configuration possible with no luck.   I originally thought it might be the stack-ring speed – I corrected that today and it is running at 32GB –
The only thing I can think of now is it might be a hardware limitation on the 3750G-16TD-S ?
Q. What performance of the 10 Gigabit Ethernet port on the Cisco Catalyst WS-C3750G-16TD switches?
A. The Ten Gigabit Ethernet uplink on the Cisco Catalyst WS-C3750G-16TD switches is 1.25:1 oversubscribed and provides maximum throughput of 8Gb/s.   –
Any advice or thoughts are greatly appreciated.
Everyone's tags (1)
VIP Super Bronze
What version of IOS are you running and what type license level do you have for each device?
IOS level is 12.2.55.SE3 - IP Base license level.  I am leaning towards the stackwise limitation of the 3750G - Any thoughts?
Hi Rudy,
Did you get to the bottom of your problem? We're attempting a similar ether bundle: our stack is made up of various 3750s, and we're trying to bundle a 3750G-16T 10G port with a 3750X 10G port.. we've tried proven configurations, but can't get the bundle operational when we include the 3750G-16T.
Our error is as follows:
#channel-group xx mode passive
Command rejected (Port-channelxx, Tex/y/z): Cannot configure interface for bundling
Any information would be greatly appreciated.
986
