Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ether channel question
Hey guys.
I have two 4500 series switches I want to create an ether channel between them.
on the one switch I'm going to do this
4507 switch
interface TenGigabitEthernet4/1
description FL02 Ten gig link to 4510 on FL01
switchport mode trunk
channel-group 150 mode active
spanning-tree portfast
interface TenGigabitEthernet3/1
interface Port-channel150
description 20 GIG Link between 4507 FL02 and 4510 FL01
switchport nonegotiate
4510 Switch
interface TenGigabitEthernet5/1
end
interface TenGigabitEthernet6/1
Can someone look this over and let me know if there are any issues.
Brent
1 ACCEPTED SOLUTION
Re: ether channel question
Much better.
jerry
Remove spanning-tree portfast from the physical interface. You will create spanning tree loop with this command.
jerry
so...
Switch 4507
Switch 4510
description FL02 Ten gig link to 4507 on FL02
description 20 GIG Link between 4510 FL01 and 4507 FL02
Much better.
jerry
Thanks a ton Jerry!
Just realized something, I see you are using port-channel number 150. I am not sure the switch can go that high. What IOS version are you running? If you post the output of show ver, I can find out.
jerry
yeah I realized that as well .. I changed everything to reflect 80
667
